I just bought a used Toshiba 52" HD Flat Screen Floor Model tv. It shuts off on it's own and I've had to unplug the tv and then plug it back in for it to turn back on. Help or suggestions on what I should do or can do to fix the problem???
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand,
Posted on Aug 06, 2010
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
How do I get my home tv to be my computer screen?
plug your AV cord into your computer, it must be a flat screen HD tv tho
Dec 27, 2009 | Toshiba TheaterWide 52HM94 52" Rear...
I have 52 inch flat screen samsung, my tv shut off
YOU HAVE A MODEL THAT HAS A FACTORY DEFECTED POWER SUPPLY.I HAD SAME ISSUE BUT KEPT DIGGING AND CAME UP WITH THE SAMSUNG CUSTOMER SERVICE @1800SAMSUNG GAVE MY SERIAL NUMBER AND MODEL AND FOUND OUT THERE WAS FACTORY DEFECT THAT THEY WILL SEND OUT A TECH TO REPAIR FREE OF CHARGE.THE STORE I BOUGHT IT FROM DID NOT HOWEVER HAVE THAT INFORMATION UNTIL I GAVE IT TO THEM ......WINK WINK
Oct 08, 2009 | Samsung 52 in. Flat-Panel LCD HDTV
Toshiba projection tv with lines on screen
I have seen a lot of sets where the problem only happens when the set is first turned on---99% of the time one of the two STK-392-110 CONVERGENCE chips this set uses is Flakey--intermittant---The only way to know is replace both of the convergence IC's and see what you have---a bad IC can cause the set to shut down---and sooner or later the set will just shut down and not come on at all.
Let me know if you need more information about this type of repair as I have done hundreds of sets with this type of problem----every one I have ever seen where the convergence was intermittent----replacing the two IC's cured the problem.
REGARDS, SD TECH
Oct 01, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
Toshiba 52" REGZA has a grainy picture
There is no easy (read: cheap) solution for this. Especially because your TV is so big, the only thing that will look good on it is something that plays at the very least 720p HD output.
I don't know what your DVD player model is, but you want an upconverting DVD player, and even then, the quality will not be full HD. The only thing that is full 1080p HD on the market today is Blu-Ray, and game consoles like XBox 360 and PS3.
As for the sports, it depends on the TV you bought. If the deal was too good to be true for a 52" TV, you probably got one with a low Hz, or a high refresh rate. This means that the images played don't update quick enough for high motion video like action movies and sports, which is why it's blurry. Mine has a 3ms response time, by comparison.
Hope this helps, please rate me.
Feb 21, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Sony 52" flat screen will shut off and then come back on. What is the problem?
please mention exact model number of your Sony 52" tv to provide you help.
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 52HL167 52" HD LCD
I have similar problem. Sometimes it will show only a blank screen. Just unplug the AC cord, wait a few seconds and plug the AC cord back in. This will reset the processor and the picture is back. It happens once a month. Not a big issue to call warranty service.
Jun 21, 2008 | Toshiba 52HL167 52 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
