Question about Vulcan GRC65 Deep Fryer
I have a Vulcan Deep fryer model 1GRC65. It keeps setting off an alarm and it says "High Temp" but once in a while it says "Probe Short" How can I fix this?
SOURCE: Vulcan deep fryer GR-45 Manual
recycle pump
Posted on Sep 08, 2008
  • 19 Answers
SOURCE: Vulcan Deep Fryer, burners shut off, remains off!
sounds like your gas valve to me, you need a manometer to test it under gas pressure.
Posted on Feb 07, 2009
Treefrog15
  • 127 Answers
SOURCE: need directions on how to clean vulcan deep fryers
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/F35640.pdf
Posted on Feb 25, 2010
kebah
  • 684 Answers
SOURCE: oder vulcan deep fryer, pilot lights and stays on,
the wiring connections may have been interchanged.
Posted on Mar 31, 2011
Why does my fryer says shorted probe
You need to replace the thermostat probe. That probe controls your heat and prevents it from over heating or not heating so if its out it has no way of being able to do so so it stays off. I couldn't find part but call manufacturer and provide serial number and they will get you everything you need and even help with any small questions.
Aug 26, 2014 | Vulcan Hart 2GR45DF LP - 45-50-lb Fryer w/...
My fryer heat up to 285 then quit then try to light but want,
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
Jun 25, 2011 | Frymaster Dean 2424G Deep Fryer
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem...
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Feb 03, 2010 | Kitchen Appliances - Others
I have a ef3 vulcan, when reaches temp, the pilot goes out.
Set the thermostat to 350 degrees,get a thermometer and put it in the oil,when the unit shuts off look at the temp of the oil.If the temp of the oil is higher then the thermostat is bad if not the hi-limit may be.Let me know.
Apr 04, 2009 | Vulcan EF3 Deep Fryer
HI showing on digital display frialator 14ss/chhov
When high is displayed it means that the probe and controller is reading that your oil temp is 30 degrees over your set temp. Use an external probe, locate it about one inch above your probe in the tank check actual temp and compare to your set temp. If you find that it is not 30 degrees over than there may be a problem with your probe, wiring or the digital controller. With a multi meter you can check your probe resitance it should be at 942 ohms at 350 degrees.
Jan 26, 2009 | Pitco Frialator 35C Deep Fryer
The fryer was working normal. Then the temperature light went out and the fyer is not coming on whe I flip the off an on switch
The first thing you need to check for is a high temperature limit cutout switch. It will be located near the gas valve but on the right side it wil have a cover that will snap open. it is about the size of 4" X 1 1/2". Once you get it open puch the button in you shoul dhere a click. When you hear the click you are reset. Once you turn the fryer back on use a temp probe or a type K thermocouple w/ a meter to check temp. if it starts over riding temp shut the unit off and replace the t-stat and the t/l cutout switch.
Thanks
Jul 20, 2008 | Garland AF-5025 Deep Fryer
Vulcan Gas Fryer Overheating
I'm confident that the issue is the thermostat. It's the only thing there to regulate temp and from the sound of it, it's not keeping up. The bulbs can gas out and then they're about as useless as an empty soda can as far as temp regulation goes.
Nov 22, 2007 | Vulcan EF3 Deep Fryer
Vulcan GRC65 Deep Fryer Logo
49 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
