Question about HP Pavilion dv9000z Notebook
I am trying to get my HDMI output to display my computer screen on it. I am not getting a signal according to my TV. What do i need to down load or turn on to make this happen? I can not find the option to add a second monitor in my control panel or anywhere. Please help!!!
  • HP Master
  • 12,061 Answers
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Tip
How to Connect PC to HDMI TV Step 1 Turn your...
  1. Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
  2. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
  3. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
  4. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
  5. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
on May 24, 2010 | Computers & Internet
Hi I have acer laptop, I have a cable one end is hdmi and the other side rgb, is there a down load driver so it will work. thank you
If you're trying to display output from the laptop to the Vizio you'd be better off using an HDMI to HDMI cable. The VGA port on the Vizio E320 only supports 640x480 resolution; you have to set your display output accordingly, usually in control panel. Using HDMI you're able to keep the signal HD, @720p. The E320 also supports 1080i, but you're not going to see all 1080 lines. If for some reason you're trying to go from the Vizio to the laptop it just doesn't work that way.
Jun 24, 2014 | Vizio E320VP 32" LCD TV
How do I connect a laptop to this tv?
It will depend on the laptop's available external video ports. You can connect a VGA cable from some laptops to the VGA port on the TV. Then plug in a 3.5 mm audio cable from the headphone jack to the PC audio in port. (The audio connection is optional. You could continue using the laptop's speakers.)
Make the connections with the TV and the laptop off. You may need to enter the BIOS to enable the external video port. (It can be turned off to save power. The BIOS is accessed on boot by pressing a key (Esc, F1, Del) noted on the splash screen. For Win8 machines, you'll need to do a special restart.) Then turn on the TV before turning on the computer. The TV monitor should be automatically recognized for resolution and refresh rate. Next, if you have a Windows system, right click on the desktop (pick a spot with no icons or running programs). Click on Screen Resolution (or perhaps Graphics Properties, depending on the OS). Set the monitor to duplicate the screens or send data only to the TV screen.
I'm not sure if the HDMI ports will understand a computer signal. (Not all TVs can interpret the computer's HDMI signal; it is different than that of other set top boxes.) You can try the following connections.
If your laptop has a DVI output, use a DVI to HDMI cable (or adapter) to connect to the TV. Then connect the HDMI cable to HDMI 1 and use the PC audio connection as above.
For an HDMI output, use an HDMI cable. (You will still need the audio cable unless you can reset the audio signal to output on the HDMI port. Go to the Control Panel and then the Hardware and Sounds section. Under Sound, select Manage audio devices. Then in the Playback tab, make the HDMI audio the default.) For Display Port or Thunderbolt outputs on the laptop, you will need a DP to HDMI adapter.
If the HDMI port doesn't understand the computer signal, you'll need to use a converter to go from the computer's output to component video or to VGA. Then connect the converter's output to the appropriate port on the TV.
I hope this helps.
(To access the Control Panel in Windows 7 and earlier versions, click Start and then find the Control Panel in the right hand column. For Windows 8, press the Windows key + X (or access the Charms menu on the right-hand side (Win+C) and choose Settings). Then select the Control Panel.)
Oct 13, 2013 | Haier L42B1180 - 42 1080p LCD HDTV
Hi, When I connect my Samsung RF711 laptop to my Sanyo LCD-42XR9DA TV HDMI to HDMI, and source the HDMI 1 input and press OK I do not get any laptop display on the TV screen at all. I have spoken to both...
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Apr 22, 2011 | Televison & Video
HOW To Make MY TV WORK ON MY COMPUTER ?
Hi
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Oct 04, 2010 | Computers & Internet
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Blue no signal screen in the middle of playing a game - ps3 hdmi
Have your tried a different plug HDMI plug on your TV? Maybe bring your PS3 to a friend who has HDMI and try it on his TV. What about a diffferent HDMI cable?
Could also be your HDMI on your PS#, but try these other simple tasks first.
Good Luck
Sep 08, 2009 | Sony Playstation 3 (PS3) Console
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
HP Pavilion dv9000z Notebook Logo
337 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
