Question about Sanyo Cinematic Progressive Scan DVD Recorder
I am having the same problem with the Sanyo DWM-3900 cutting off after only a few minutes of playing. The heat sinks get hot and the fans do not turn on. I have read the earlier recommendation to remove the thermistor labeled H2 to solve this problem. Where on the circuit boards in the Sanyo DWM-3900 is the thermistor labeled H2? I have looked and do not see it. Thanks
  • rrrrrlewis Aug 06, 2010
    Thank you for your detailed explanation of the problem. I have a multi-meter, and may attempt the repair myself.
  • Sanyo Master
  • 12,061 Answers
Http://www.retrevo.com/support/Sanyo-DWM-3900-Home-Theater-Systems-manual/id/311dj898/t/2/
This is NOT , the result of any Thermistor, Unfortunately, you have a problem with your power supply/output Amplifier. These output devices have faulted and will more than likely need replacing.
The Thermistor is a safety device, and will NOT cause these symptoms.
You will have to start your troubleshooting steps at the Power supply and ensure that ALL the voltages are correct there before proceeding further.
Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Sanyo Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on Aug 06, 2010
  • ronald jeffcoat Oct 05, 2011
    Did rrrrrlewis solve this problem? I have the exact same issue, it shuts down after about 3 minutes. I too was searching for the thermistor.
Hi my ps3 keeps freezing after playing a game for a few minutes. The systems appears to be getting hot fast.
Because the console feels hot, it appears that heat is adequately reaching the heat sinks which are attached to the major heat producting chips.
Unfortunately, it sounds as though your cooling fan is either obstructed or has failed. This problem can only be rectified by opening the unit and clearing dust, or replacing the fan.
Sony will repair the unit for you for a fixed fee, I believe the fee is $150.
Hope this helps
Matthew
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
Shuts off 5-10 minutes, no 12 vdc present, fan not turning
You'r fans are still good just the board is not giving it any power. I took myne apart and blew it out with my compresser and that helped some.... But i just got a 12V wall plug in screwed a hole in the back and ran diffrent wires to it.
Oct 26, 2008 | Dual DWM-3900 System
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Shuts down after a few minutes
have u solved the problem or still needs help, post me
Rifaa
Mar 20, 2008 | Dual DWM-3900 System
DUAL SANYO DWM-3900
I had tha same problem the fan in the back of the unit is blown I went to a local computer store and bought another fan a little bit bigger and i don't have the overheating problem any more.
Mar 09, 2008 | Dual DWM-3900 System
Sanyo DWM-3900
In DVD mode, Progressive Scan shows on screen. Just press the stop button on the front panel for about 5 - 10 seconds and it will go back to standard mode.
I did the same thing tonight and I just tried pressing buttons
Simon
Jan 18, 2008 | Dual DWM-3900 System
Sanyo DVD player DWM-400 won't do work
I have a similar problem with the Sanyo DWM-400. I also cannot turn power off. Even when I unplug it and then again plug in the power cord it will come back on after several minutes all by its self. It will then work okay for a few minutes and will play a DVD and will suddenly quit showing a picture. It seems that something is overheating shortly after turning it on. After letting it sit and cool down for a while it will play again but only for few minutes. Although I have had this player since April 2004 it has rarely been used. I estimate it only been used no more than 10 hours total. With so many buyers having this problem Sanyo should issue a recall on this model.
Nov 26, 2007 | Sanyo DWM400 DVD Player
Dwm-3900 wont play dvd's
Because you have limited knowledge of your products history, first ensure that your Country Code is set correctly. Using your remote, access your User Menu/Setup > Country Code > U S > Memory > Setup. I am assuming that you are in the US, and are trying to view Region 1 DVD's. Please update for further instructions if the above doesn't solve your problem....good luck.
Aug 01, 2007 | Dual DWM-3900 System
Televison & Video Logo
94 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
