Question about HP Scanjet 5590 Flatbed Scanner
How extract jammed paper - HP Scanjet 5590 Flatbed Scanner
    Scholar:
  • 55 Answers
In a scanner? Uhh haha, you should have a jammed scanner, its just a sandwich type device. If its a printer, you must open up the trays, or a little plastic casing(itll stick out if you look, its a flap) and pull out the paperjam
Posted on Aug 06, 2010
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Apr 18, 2010 | Brother MFC-465CN InkJet Printer
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
Jammed paper
On the bottom rear of the printer there should be an access door with a thumb latch to open it.
Jun 27, 2009 | HP DeskJet 5740 InkJet Photo Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
Paper Jam
Have you opened the back cover to see if you could extract the paper there?
Have you removed the paper tray, and attempted to extract the paper from the bottom side of the unit?
Apr 26, 2008 | Brother HL 1440 Laser Printer
Piece of paper 1 inch by 2 inches jammmed and won't eject when I touch start button. I can't even see it with the cover open.
you have to open up your printer covers to extract that jammed paper. However, if you haven't tried tinkering with anything electronic before you will have to seek technical assistance from a qualified expert, but if you're willing and determined to extract that piece of paper, i suggest first you unplug any power connection from your printer, then unscrew the visible screws of the cover which is nearest the jammed piece of paper. never turn any cylinder if it resists your effort, however, try to manually turn cylinders where that small piece of paper is wedged until it comes off. Try to pull down on that piece of paper using a hair puller or forcep.
Apr 01, 2008 | Computers & Internet
Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Aug 22, 2007 | OKI B4300 Led Printer
HP Scanjet 5590 Flatbed Scanner Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
