Question about Fuji FinePix S5000 Digital Camera
The battery case at base has cracked , and now can't be locked closed. can these be replaced (easily)
    Problem Solver:
  • 17 Answers
Yes they can be replaced, but i am quite unsure if you could do it on your own. Better go to a Fuji Film customer care center and get it mended. It'll not be covered in warranty and you'll be charged for this as it is physical damage.
Posted on Aug 06, 2010
Kids dropped tablet. dead. Opened back and found display connector cable/film had cracked. Is there a fix for this? Is the connector integral to the display or an easily replaced cable?
take it to a repair shop but the problem really is when it is dropped , look for a new one as repairs will cost close to a replacement unit
Dec 20, 2015 | Tablets & eReaders
Batteries dead cannot open safe
Looks like you need to replace the batteries in the keypad.
Remove and discard the screw (if equipped) at the base of the lock case.
2. Turn the electronic lock case to the right (clockwise), from 12 o'clock to 2 o'clock, and remove.
Insert 4 new AA batteries (not included) to powerthis lock.
Replace the electronic lock case and turn to theleft (to 12 o'clock) to reassemble.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/vincent_456bdeb17f8dd0de
Oct 19, 2015 | Home Security
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :)
DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
Sep 13, 2014 | Olympus SP-550 UZ Digital Camera
My kindle wont turn on no light wont charge
The first item to check is the battery. No easy way to do it without opening the case. If you decide it is the battery, you can order a replacement from Amazon. You then should should consult YouTube videos to see how to crack open the case. Once the case is open, the battery swap is straightforward and it closes easily.
If you decide it is too difficult, you can ship the device to several repair depots. They charge around $80 to replace the battery. You should include the charger as that my be why the battery has failed.
Sep 27, 2013 | Amazon Kindle Fire HD
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
How to put batteries in ds3607
a1 locksmith
advised me to Remove and discard the screw (if
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
NOTE: The yellow LED will light when the batteries
more info at sentry safe sales service
Jan 21, 2012 | Sentry Fire Safe - Safe - DS3607
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
this lock.
left (to 12 o’clock) to reassemble.
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Broken screen
First if you have a broke LCD " Cracked" than ok its bad.
but if the back-light is not working and you cannot see a image easily it most likely is something else.
  1. remove the case screws
  2. remove both sides of the case
  3. on the lens side their is a shinny black piece of tape VERY carefully remove it
  4. release the ribbon cables
  5. take off the battery door
  6. de-solider the red and black wires closes to the battery door REMEMBER how they go
  7. turn the camera over
  8. on the right hand side there it you control board or cable
  9. VERY VERY carefully pry up the control board it can rip very easily
  10. now you can remove your LCD you might have to pry it up CAREFULLY because it might be taped down.
Hope this helps It is not that easy to repair digital cameras if you feel unsure about the repair leave it to the experts it would only cost you around 85.00 + Shipping to have the camera fixed. I repair these all the time and Know it is not that easy to fix.
Dec 23, 2007 | Casio Exilim EX-Z750 Digital Camera
Batterry replacement for Skagen-355LSSM
Without a Case Closing Plier ($15 to $20) or a Case Closing Press ($15 to $50) you will not easily be able to get the back to snap back in - see WikiAnswers
Nov 04, 2007 | Skagen 355LSSM Wrist Watch
Fuji FinePix S5000 Digital Camera Logo
35 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
