Spark plug always dirty - Computers & Internet
  • 32,281 Answers
You have posted your query in the wrong area, this area is for computers etc.
Anyway, if the spark plugs are black and sooty and your exhaust is blowing black smoke then the fuel mixture is too rich, The carburattor need to be tuned/adjusted so the fuel mixture is running leaner.
Posted on Aug 06, 2010
Hard to start fuel pump has been checked
Need much more information about the car, age, care it has had. Only 4 things cause hard start. Lack of Air coming into the intake, Lack of Fuel, Lack of spark, Lack of torque from the starter. Assuming the starter is good & battery, and fuel is there, i would check the spark plugs, and spark output. If it has a lot of miles check the Air Filter. The injectors could also be clogged. I always dump 2 bottles of injector cleaner in the tank every 2 months. If you have never done this i would go for 3 bottles. Again the spark cannot be weak, fuel pressure cannot be low, or have restrictions like dirty a fuel filter, or dirty fuel injectors or even bad Gas. And last a computer problem providing incorrect timing to the Injectors or Spark Plugs.
Apr 23, 2016 | Nissan Pathfinder Cars & Trucks
P1190 code 2000 toyota sienna
multi misfires can be from injectors --dirty and not squirting properly or low fuel pressure ---fuel pump or dirty filters
plugs are only half of a misfiring problem and the injectors are always left out
Next time include all details like make, model , year of car in your question to get a better answer
Dec 07, 2015 | Cars & Trucks
My car doesn't always start after a rainy day.
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 01, 2012 | 1991 Oldsmobile Cutlass Ciera
Engine runs rough
Rough engine running is an indication of many things, which could be one or more of the following:
  • fouled fuel
  • dirty fuel line/filters
  • dirty or NO engine oil
  • dirty intake manifold/throttle body
  • faulty spark plugs [for petrol/gasoline]
  • incorrect engine timing
  • faulty ECU [for EFI engines]
  • faulty idle-up controller [rough idling with a/c engaged]
This is a broad answer to your engine symptom, but it is always best to have this checked by a qualified engine mechanic.
Hope this helps.
May 21, 2010 | 2000 Nissan Maxima
SPARK PLUGS FULL OF OIL
Do you notice a puddle under the car? Or smoking when you shut it off? The rocker cover gaskets are the culprit. If you have the spark plugs in a well inside the rocker cover, the will fill up with oil and also leak out the back. You can replace the gaskets, a fairly easy job, you have to pull everything off the top of the engine to get the covers off. And they give you the new seals for the spark plug well with the gasket kit. They only go about 10 years, I replaced mine and they are starting to leak again. Hope this helps.
May 19, 2010 | 2002 Mitsubishi Lancer
My check engine light is on and the code is reading p0304 what could be the problem
You have a Misfire at Cylinder #4 meaning:
Dirty, fouled or malfunction Spark Plug at #4 Cylinder. Remove the Spark Plug and check the igntion (spark end).
Ignition (Spark Plug) Wire malfunction for #4 Cylinder.
Misfire from the Coil/Distributor at the #4 connection from Cylinder #4.
Get a Spark Plug/Wire/Coil/Distributor tester and check the Spark Plug, Wire and Coil.
I always recommend changing everything in sets meaning: Change all Spark Plugs and Wires.
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Feb 18, 2010 | 2003 Ford Expedition
Jerking Problem
Get a botle of spark. Spray plugs and al your electrical conectors and try again. I think your problem will be solved. If the plugs getting dirty like burned inside . Im sure you need new rings.
Jul 11, 2009 | 1995 Mazda 626
My yz wont start, changed spark plug it ran for 1/2hr then died
Couple things- 1. If the plug was dirty after 1/2 hour you have either the wrong heat range plug(too cold) or 2. a fuel/carb issue. Buy a hotter NGK plug, ask for help the numbers don't always make sense. Use only full synthetic 2 stroke (I always liked bel-ray) and fresh 93 octane fuel. When you find a plug that works good buy a case of them, 2 stokes will foul plugs period. And some advice with your solution, never head into the woods without a spare plug, they will foul at the absolute worst time.
Don't forget to rate please!
Mar 13, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
Sparks bluish bright purplish? very small sparks, after plugging in to wall socket. also rythmically every 3 seconds a cracking sound is heard concomittantly ..???!
Sounds like it needs a good cleaning. Does this one have the metal bars that pull out? I have a ionic pro and when it gets dirty it will emit small sparks where the dust connects from one bar to the other. It also has a pull up wand that cleans the wire that help build the charge. If this is the system that changes the charge on the ions to attract them to plates, you will see small sparks when it becomes dirty. Mine always let me know by the sparking sounds it makes.
Aug 02, 2008 | Bionaire BAP825-U Air Purifier
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
