Question about Toshiba Satellite L305-S5908 Notebook
I want to reboot my laptop, what buttons do i press to do it quickly?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 74 Answers
Ctlr+alt+del is an option
Posted on Aug 06, 2010
Reboot need on Toshiba Satelitte
Rebooting from the Windows OS can be done y a variety of means, depending upon the version of the OS. Clicking the START button or pressing the Windows key on the keyboard will get you to the POWER option where you can select RESTART (which is a reboot).
If you are not in Windows at the time, you can usually press the CRTL-ALT-DEL combo and get a reboot. Lastly, press and hold the POWER button until the device fully shuts off. Wait a few seconds and then power back on to get a reboot.
Dec 15, 2015 | Toshiba Computers & Internet
How do i reset a bios on my laptop
If your model is fairly new:
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Otherwise press ESC quickly after it comes on, and then it will show somewhere "press XXX for setup" or similar
When you are in the BIOS, then there should be an entry somewhere that says "reset to system defaults" or "reset factory defaults" or "reset optimal" or similar. Do that, then reboot. Bios will be reset.
Nov 30, 2010 | Toshiba Computers & Internet
How do i reboot my laptop? its a acer
Use Start button and then Shut down then choose restart from the options if using Windows. Use the reboot command to reboot Linux. If frozen, press the power button for a while to shut it down and restart it by pressing the power button again.
Nov 26, 2010 | Computers & Internet
How do i reboot my computer
To reboot the desktop machine, kindly press the power on button for few seconds / small button(reset) below the power button to reboot the computer.
If its laptop follow the below steps
Determine what operating system it uses. Finding out what operating system your laptop uses will let you know what key combo (such as "Ctrl+Alt+Delete") can exit you from usage and trigger a reboot or shutdown.
Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up.
Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately.
Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
Oct 15, 2010 | Computers & Internet
How do I reboot my acer laptop with my copy disk?
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery CD/DVD with the laptop. or 1.Press the start button from the start menu depending on your operating system(win 2000,xp) 2.Press Ctrl+Alt+delete combination from the keyboard. 3.If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot or shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot. Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually. A few seconds should do unless you have additional problems.
All the Best!
Sep 12, 2010 | Computers & Internet
Crashes.
Since it's not hot the main suspect is the hard drive. I'd recommend swapping the drive out and reinstalling the operating system.
May 20, 2010 | Acer Extensa 5420-5687 Notebook
What button to press to reboot laptop acer aspire 2930
You turn it off ...then back on to reboot.
click the start button - select turn off computer
Mar 24, 2010 | Acer Aspire 2930-4661 Notebook
Laptop needs rebooting
Im using the advent 4211-b and its flawless.small,light ,looks good has all you need built in and also has choice at startup windows or recovery.cant fault it.if you cant reboot.press power ,get as far as you get ,press and hold power button til switch off press power button again to restart(boot)if youre already in windows and cant shut down or reboot do the same.as long as you dont turn off and unplug no damage to the system will occur.
Jan 04, 2009 | Computers & Internet
Reboot my hp laptop
Hold and press the power button down ( and dont let go ) for at least 10 seconds or untill laptop shuts down and you can reboot by powering it back up by pressing power again. If it still shows access denied after you rebooted then more than likely you need a password.
Jan 02, 2009 | HP Pavilion DV6405US Laptop
Pc frozen how do i reboot
rebooting is restarting a computer..try pressing control +alt+delete simulataneously and then shut down..if that doesnt work..press the power button on a laptop for a few seconds..for a desktop press the reset button below the power button(if there is one) or the power button or remove the power cord...hope it helps!
Nov 08, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite L305-S5908 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
