Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
A friend unplugged all wires frm inside the compaq i need instructions on how to reconect it so it wrks again
    Scholar:
  • 83 Answers
First check your hard drive fixed with screws in cabinet. Then if it(your hard drive) is a parallel it must have 4 pins for power and around 40 pin on its back. Just find a four pin connector that will coming out from pc power supply or smps. Just connect it to your drive for power and find 40 pin connector that is also connected to motherboard on its other side insert that plug in hard drive carefully. Don't use force to connect it because it can bend or break pins of hard drive.
Or
If you have sata hard drive its also have slim face power jack comes from power supply or smps. Its other cable is small faced some time red or some time black in colour connected on motherboard on one side and just take it other side and connect it on hard drive.
For future never try play with your pc like this because it can cause hardware problem in your pc.
A friend unplugged all wires - sata%20vs%20pata.pngmoz-screenshot-2.pngor
http://geekspeak.org/articles/hard_drive_technologies/parallel_ata_hd_800x618.jpg
or
for further any help or to thank me. Mail me on my email id Ejaz89@live.com
Posted on Aug 06, 2010
Dome light, Cig lighter, Radio don't work. Checked the fuses in the compartment under the Drv side, and the firewall on the passenger side in the engine are good, and all fuses are good. Horn wrks.
Check along the firewall wiring and look for an in line fuse inside a rubber connector that unplugs from each other and see if the fuse is good. Some models have one on each side of the engine on firewall. Also check your wiring harness for breaks in the line or a bad ground,
Hopes this helps Mike
Apr 05, 2015 | 1993 Chevrolet K1500
Smart T.V Sumsung Got Stuck
It sounds that your TVs' timer function is set to 'ON' for 15 minutes time. Check it, and make it 'Off'. Refer its user manual for details.
Jul 21, 2013 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Hi! i was playing call of duty online when the electricity went off. after some time it came back and when i tried to reconect to PSN it dosnt let me. it does get the IP adress but there is an error in the...
Hello
Try a router reboot.
Unplug all wires to the router.Including power.
Let sit for 3 min.
Plug power back in first.Then plug ethernet wires back in.
Now try playstation again.
Aug 01, 2011 | Computers & Internet
Turn signal indicator the plastic part on the inside broke switch still wrks is it repairable without taking out the steering wheel?
The Turn Signal Switch is accessed by removing the steering column plastic trim. Just a couple of screws to remove switch and unplug wire harness. Install new one by plugging wire into harness, tight screws and replace plastic trim.H ope this helps!
Jun 16, 2010 | 1994 Ford Probe
I can't check my mail
I had the same problem - and it only started yesterday.
I had to allow 'mail.yimg.com' through my firewall - something I was always able to block. It makes me wonder exactly what mail.yimg.com is and why are Yahoo making it required now? Probably some sort of tracking ****...
Sep 18, 2009 | Yahoo Mail
I need to replace the stock shaft radio with a brand new aftermarket head unit. NEED HELP!
is this a post raido or flat face? flat faces will have din pins 2 hole each side of raido have to get a tool to remove --also get wire adp. frm parts store will b -easy that way
Apr 17, 2009 | 1986 Ford F 250
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Motorazr V8
Dear Sir,
I had a motorazr V8, the glass of upper screen has broken, so I want the solution. can this screen has changed, please revert back to me.
Vijay Tyagi
9871094350
vkt_31montage@yahoo.co.im
Mar 07, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
166 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
