Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Dear Sir/Madam, The garbage disposal does not start after I turn it on (no sound at all). I tried to press the red reset button on the bottom. After that, I hear the humming sound after power on but still it does not work. Can you give some suggestions to try diagnose further? Thanks! Weibin
    Problem Solver:
  • 5 Answers
Something has it clogged. Look on the bottom of the disposal. If there is an exposed end of the shaft, you can use channel locks, vice grips or a wrench to try and spin the shaft. Be sure the power is disconnected to the disposal while doing this.The shaft should free up. You may have to turn the shaft a short distance in both directions to completely free the motor. If the motor doesn't free up, there is something of substantial size hung in the blades and the motor will have to be removed to be serviced or replaced.
Posted on Aug 06, 2010
Where is reset button on gemline garbage disposal
To reset garbage disposal follow these simple instructions:
  • Make sure that the disposal switch is in the "OFF" position.
  • Gently press the red button in to reset garbage disposal. ...
  • Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again
How to Reset Garbage Disposal InSinkErator
Oct 14, 2017 | Electrical Supplies
My garbage disposal is not working' only humming sound, no action. I'm not sure if I found the reset button. A red plastic, could be a button, on the bottom of my Badger was moved around, not so much...
There is a wrench that came with your disposal. It is about 1/4" and has six sides. Be sure it is turned off. Insert it in the bottom in the middle and move back and forth a few times. Remove it turn on the water and try again. If it hums repeat. If no noise press reset, otherwise it is working.
Sep 02, 2013 | Electrical Supplies
Garbage disposal
My checklist for garbage disposals:
(1) most disposals have a little red RESET switch on the bottom. Once the impeller will turn manually, press the reset button, and you may get back full operation.
(2) 120 Volt wall switch may have burned out. They're only rated for 100,000 operations before they burn out.
(3) If the impeller is difficult to turn, you may try to use an "flywheel wrench", which is just an offset Allen wrench that fits into the bottom of the motor, and can be used to turn the flywheel manually, freeing the impeller and allowing the reset to work.
(4) The circuit breaker in the breaker panel in the basement may have tripped, cutting power to the switch controlling the garbage disposal. If tripped, turn off the switch to the disposal and reset the breaker.
(5) Disposal motor may have died.
This How-To seems like a nice one:
http://homerepair.about.com/od/plumbingrepair/ss/fix_disposal.htm
Nov 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Describe how to use the garbage disposer- currently it doesnot work- humming sound, no grinding
Look on the bottom of garbage dosposal in the center you will see a allen type fiitting. I believe it takes a 5/16 inch allen wrench to fit it.Insert proper size allen wrench and turn it manually back and forth. It sounds to me like you have something in there that that is not allowing it to turn. By using the allen wrench to turn impeller you should be ably to free it up.Sometimes it helps to run very hot water thru it as you are trying to frree it up. If you can get it turning freely with wrench remove wrench and turn disposal on. If it still is not free try above procedure again. If it trys to start and stops buzzimg look closely at bottom of disposal there will be a small red button. This is a reset switch. Push it in and continue trying to free blockage. Hope this helps you. Thanks
Nov 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal doesn't turn on, I checked the plug and it works. What do you think is the problem?
Every disposal I've seen or installed has had a RESET button. If there is no sound at all when you switch the unit ON, look/feel around the bottom of the unit for a small button (usually RED). Press the button in, and then try the switch again.
If the unit makes a humming sound when switched on, something is binding the mechanism and preventing the blades from spinning. If this is the case, unplug the unit and then spin it to remove blockage and free the blade mechanism. If the unit came with a large allen wrench, you can insert it in the bottom of the unit and turn it to free the blades. No wrench, no problem. Insert a small piece of pipe, a pipe wrench handle, or (my favotite) a 3/8 or 1/2 inch socket extension bar into the top of unit and turn the blade assembly until it spins freely. Once the blade assembly is freed, the unit should operate normally.
Oct 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal is not working. Making humming sound when turned on. I tried to press the red reset button but to no avail. Also tried to turn the little dosposal wrench in bottom hole of disposal but...
It is most likely plugged up there is a clap with a butterfly bolt that you turn counter clockwise remove the clamp and have a trash can under it and wiggle it to remove the lower half of the disposal, when it comes off dump it out and clean with fresh water. Then with hands free of the pump turn the disposal back on, it if still hums the motor is bad and you will have to replace..
Sep 13, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Resetting Garbage Disposal
should have came with a alen key use it. to loosen the blades that are stuck on the bottom of the gaburator theree should be a hole in the middle. Just fine a alen key that fits in the hole and turn it around and then turn it on should solve your problem
Jun 05, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
156 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
