Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
I cannot get the pc to boot up, after blowing out dust as the pc is around 4 years old and was making alot of noise so i thought i would clean it to bring donw the level of noise since then I have not been able to boot up the pc. I am running a custom setup with a asus motherboard p5n32-e sli, unfortunately after removing gcard and ram i still could not get it to boot up and the mb light is still flashing away i even tried removing the bios battery in the hope it would fix but no luck. so all I can get my pc doing atm is toflash the mb light :(
    New Friend:
  • 40 Answers
That sucks, you probably accidentally created too much static electricity and blew a mosfet or other chip that is subsceptible to static electricity. Or if you are lucky you may have just accidentally unplugged some connection or caused some debris to get lodged somewhere where it is shorting or bypassing something. Either way, recheck everything and for any loose connections and/or reblow it out watching and checking crevices that are not easily visible to make sure nothing is getting lodged anywhere that it don't belong.
Posted on May 03, 2017
lolita
  • 385 Answers
SOURCE: New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Posted on Mar 30, 2007
SOURCE: Need wiring harness guide for asus p5n32-sli deluxe motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI%20Deluxe
You can get all the files you need here.
Download and print only the parts of the manual you need or it will be almost a whole stack of paper.
Good luck with this mobo.
I've had nothing but prob;lems with it.
I'm going back to my ecs that I know works.
I suggest you search "problems with p5n32-sli".
Posted on Nov 14, 2007
  • 44 Answers
SOURCE: Asus P5N32-E SLI PLUS motherboard
All of the downloads for you mother board can be found here: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-E%20SLI%20Plus
Your manual is here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5N32-E%20SLI/e2979P5N32-ESLIPlus.pdf
Posted on Dec 18, 2007
bootz84
  • 197 Answers
SOURCE: i have a ASUS P5N32 SLI Deluxe Motherboard but
I've had similar problems to this, where the computer would start sometimes, and other times it would start, but not give me any video. I changed my power supply and the problem was solved.
Posted on May 04, 2009
graemevm
  • 519 Answers
SOURCE: System has been working fine for several years.
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
Graemevm
Posted on May 05, 2009
HI, my laptop is three years old, getting some noise from the fan, My question is can the fan be lubricated,
Have you tried blowing air through the cooling duct to clean out the dust that gets caught up in there?
Nov 13, 2013 | HP (158800-001) for Compaq Presario 1246,...
My laptop making humming noise when connected to external speakers
if its old or hasnt been cleaned just clean the ventilator and the inside of it , of dust but very gently :) if you have no experience as its a laptop it would be easyer to just get it to a workshop and ask them to clean it for you well the inside of it :P if it would be a PC you could just open the bos up and just clean it from dust but its a laptop so workshop would be alot safer to keep the device up and running :)
Mar 13, 2013 | Computers & Internet
MY E-MACHINE MODEL NUMBER T-3985 MAKES ALOT OF NOISE WHEN RUNNING.
If it is a clicking noise, then that means your hard drive is probably starting to go. If it's a humming noise, then it's the system fan that keeps the computer cool. Try cleaning the fan and if that doesn't work, purchase a new one and replace. They are fairly cheap and easy to replace. If the fan stops working, it can cause the computer to heat up and may cause components such as the processor and hard drive to fail.
Mar 02, 2011 | E-Machines eMachines Desktop PC
A friends computers fan is making alot of noise, sounds like the fan is going and making alot of noise, if you run 2 things at the same time it really gets loud. Is there an easy fix for this or is the...
hi
fan noise means one think, DUST !
or if its past its life cysle (ie: 3-5 years), its time to replace the fan.
you can remove the dust from the fan. If that noise persists, yopu must replace the fan , otherwise your friend will eventually dmage the CPU or mainboard or both.
hope this serves you well
Nov 04, 2010 | Computers & Internet
I have a 6 year old gateway desktop, it has windows vista. The computer will not stay turned on when i boot up (won't boot up), i also use it as my wireless master and do not have any issues with my...
This might be a heating issue. Considering its 6 years old pop open the case and use dust off and spray it down until there isnt any dust left near, in or around the heat sink. try that and if it doesn't work try re-seating the heat sink on the possessor and clean off all the thermal paste and re apply some new thermal paste.
Oct 25, 2009 | Gateway Computers & Internet
LG EF FF Error
I found another post that suggested the following. Did it and found wires/connections frozen with a huge piece of ice.
Make sure unit is unpluged!
Removed baskets (2), unscrewed back panel of freezer. A little tricky to get out. There will be electrical connections attached to the panel but you can disconnect/reconnect these. Mine were on the top, left corner. I used a blow dryer to melt the ice chunck. Dried up all the water, replaced back, baskets.
I then took the panel off the very back of the unit as the melted ice had drained into the drip pan. I cleaned the drain pan of water, dust. They don't make this an easy task for the homeowner. Replaced the back, plugged it back in and all is working again. Don't know for how long until this happens again. But....no more LG products for this homeowner.
We remodeled the kitchen 2 years ago and went stainless steel. My 16 year old Kitchenaide is still running in the garage. Guess I'll go back to that model when the LG bits the dust.
Jul 28, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Television is now 4 years old, have replaced the lamp 4 times, last time was last week, this lamp lasted three days am waiting for new lamp to see if the last one was faulty. is this a common problem...
Make sure all Airways do not have alot of dust builted up blocking Airways this can cause Lamps to Blow, also keep in mind these sets are only desinged to play between 5000 to 8000 hrs you cannot leave them on day and night like regular TVs,and yes New Lamp does not mean that it was not Defective sometimes companys do have a run as to where they have alot of defective Lamps it Happens
Mar 16, 2009 | Loewe Articos 55 55" Rear Projection...
Loud Fan Noise
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Apr 23, 2008 | E-Machines eMachines Desktop PC
Flickering with a clicking noise
u have an arcing high voltage. dont use this it can cause a fire
dust might play a factor... i doubt it.
Nov 16, 2007 | RCA D52W19 52" Rear Projection Television
Sony sxrd60 picture does not work
ERROR 4 ON THIS SET IS ETHER THE FAN OR THERMAL SENSOR. DO YOU HEAR THE FANS RUNNING ? SOME TIMES THEY JUST NEED TO BE CLEANED OUT, IF THERE IS ALOT OF DUST AROUND THE SET.
DON.
Aug 01, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
