Question about Stiebel Eltron DHC-E 8 Tankless Electric Water Heater
The water heater suddenly stopped working. The power light isn't on. Also, I tried switching the breakers off and on and that did not help.
  • 3,640 Answers
The most likely cause is the heating element is bad. check the elements.
Posted on Aug 06, 2010
I need help. My water heater all of a sudden stopped heating after an extension cord had shorted in the next room over. So could the problem be the breaker or the reset button which is stuck?
Check the breaker first and confirm that power is being delivered to unit. Then if power is confirmed, try the reset and make sure that power is now getting to the heating coils. If necessary, you can always jump the reset switch if it stays stuck.
Aug 26, 2015 | Water Water Heaters
No power to unit
Copy following link for tankless troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#fuse
Tankless are not protected from surge, but there is a 3-5 amp glass fuse located on circuit board.
Check outlet with circuit analyzer, and multimeter
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 28, 2013 | Rheem RTG-95DVLP Low Nox Direct Vent...
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Electric Water heater not heating all of sudden
If you have tankless, then open following link before calling service technician.
If you have ordinary tank-type electric water heater, then reset button is probably tripped out, or circuit breaker is not delivering power to heater.
Reset circuit breaker, then open cover located on side of tank and push in ECO red reset button.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
If you have boiler or indirect heater or solar heater or faucet-type heater, I would need more information, and might not be able to provide best answer.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 20, 2011 | Rheem Water Heaters
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Suddenly stopped heating water
Check the top thermostat2_bing.gif... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water just quit suddenly
First, of course, check your breaker in the breaker box. You will need to check to see if the heater is getting power before checking the element(s). Elements go out suddenly, so this could be your problem if you have a smaller one-element heater. Have it checked. Good luck.
Nov 30, 2009 | Reliance Water Heaters
Stiebel Eltron DHC-E 8 Tankless Electric Water Heater Logo
397 people viewed this question
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
