Question about Orion1934 19" TV
Can't set cable channels
Cannot get seem to get to the option to set the channels to match the cable. No cable box, line connects directly to the tv.
I HAVE A TV WITH THE REMOTE BUT NO INSTRUCTION BOOKLET. tHERE IS A NUMBER ON THE REMOTE 076NODW090. i CAN' T GET ANYTHING ON THE SET. iT IS HOOKED UP TO CABLE. HELP PLEASE.
THANK YOU,
SLH
Posted on May 05, 2008
What settings do my Samsung tv need to be on to link a digital cable box
The digital cable box will most likely connect via an HDMI connection. Simply ensure that the SOURCE selection for the set matches up to the HDMI port that the digital box is attached to. There is no need for any kind of channel scan when using this type of connection as the cable box acts as the digital tuner. If you are coming into the set on the coaxial cable line, then that is a different story. Ensure that the digital cable box is turned on, then do a channel scan to locate the channel that the cable box is using to send the signal.
Mar 02, 2015 | Samsung Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Going from cable to coby converter box
cONNECT A REGULAR OR DIGITAL ANTENNA TO THE rf INPUT ON THE coby..
Do one or both of following.:
Connect rf output from copy to rf input of TV. (set both units to channel 3, or 4 --must match)
or connect three RCA connectors (either three cables or single cable with Yellow-Red and White connectors) to the matching
connectors on TV and COBY.
This might involve DISCONNECTING some connection from cable box.... but you may decide to keep both connected ( one item to each option as described above. ) The signals from the RED WHITE and YELLOW systems will be available on the TV when you set the TV for LINE input ( there might be more than one choice of LINE-IN selections on some TVs.
May 11, 2014 | Coby DTV102 ATSC STANDARDDEFINITION TV...
How do i connect xfinity to my plasma display
If you're referring to your xfinity tv receiver (the cable box) there's a few different ways. Please keep in mind without much information, it's difficult to give a 100% direct answer.
There are four ways to connect it. We'll start with what will give you the best video quality, going to the worst.
HDMI cable: A single cable with a flat end. Your TV and receiver will have port labeled "HDMI". You plug it in, and then use your tv remote to set it to the HDMI channel. You may have source or input button on the remote. Press that, and a list of options will appear on your tv. Select HDMI. If there is more than one HDMI (as in HDMI1, HDMI2) try each one until you get a picture.
Component cable: A cable with 5 ends. They're color coded, so match up the colors. Then try that input our source button to select the COMPONENT option on your tv.
RCA cable: A cable with three ends. Color coded. Follow the same directions as above in regards to the correct "channel" to put it on.
Coax: A single cable, an end that screws in. Its connector will look like something can be screwed on it, with a hole in the middle for the pin to go into. Connect it, then tune your tv to channel 3 or 4.
Mar 30, 2013 | Comcast XFINITY
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
I am trying to hook up my cable box so i can watch tv.
At the cable box input, connect the cable (probably labeled "Cable In" or "Signal In").
Depending on the cable box model and available inputs on your TV, connect one of the following (listed in descending order of video quality). Colored phono plugs must match the colors of the plugs on each end.:
  • HDMI (a single rectangular connector at each end - sometimes you need to connect the Audio separately with a two - line cable with red and white phono plugs).
  • YPbBr, AKA Component (Cable with Red, Blue and Green phono plugs, plus a separate Red and White cable set for Audio).
  • S-video (a single round connector and separate Red and White audio cables).
  • Composite (Yellow video cable plus Red and White audio cables, usually sold as a single set).
  • RF out on the cable box connects to ANT or Cable In on the TV with a coax cable.
The various options are always grouped in some manner on both the Cable box and the TV. On the TV, note which input set you use, for example, "Component 1". This is the input you will select to watch whatever channel you select on the cable box.
An unused output on the cable box can go to a video recorder. Some cable boxes may permit setting up two different channels for this purpose; others will only put out the signal from one channel at a time on all outputs.
You may, if you prefer, connect the audio cable from the cable box to a stereo receiver instead of the TV. Usually people connect the audio to the TV, then connect another audio cable from "Audio Out" or "Monitor Out" on the TV to the stereo receiver. That way the sound is from whatever video source is currently selected, and the TV remote control can be used to set the volume. TV sets with this option usually have a setting to turn off the internal speakers so you hear only the external stereo speakers.
Feb 05, 2011 | Televison & Video
No tv channels with Philips 42FD9935/17
If you are using a Cable Box, then select the Cable Box option in the TV. If you have connected the Antenna directly to the TV, then select the Antenna option in the TV under Menu options. Try performing the Auto program.......If using a Cable Box, then no need to perform the Auto program. If the issue persists, try resetting the TV to the factory settings and check if it helps.
Jul 25, 2010 | Philips FTR-9964 Tuner/Receiver for Plasma
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
Owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
Mar 15, 2008 | Sanyo DVW-5000 DVD Player/VCR
Orion1934 19" TV Logo
85 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
