Question about Sony DVP-C650D Multi-disc DVD Player
I have a dvp-c600d dvd player 5 disc tray. a pin broke inside on the dvd tray located on the bottom tray of dvd tray I put a new pin and dont know where to align the wheels for tray and disc position and also a reset combo i found before 3 diff buttons?
Did you find a solution? I have one to and the disk tray is misaligned and I don't know how to fix it...and I have no info showing on the digital screen..other buttons don't work..so I don't know if I have to reset the machine...could you tell me how to rest it?
Posted on Jan 05, 2011
Unlock tray in sony dvd player DVP-NS728HP/B
Master reset it. If the tray is stuck then in front of tray you will find small hole. Put a pin or needle to execute emergency exit of tray.
BMW Parts
Aug 25, 2012 | Televison & Video
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
Cannot insert disc
If the problem is with the tray of the player, there will be a small hole at the front panel near the tray. You just need to put a pin into that hole, the tray will come out if it is stuck inside.
Thanks
Aug 09, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
It wont play dvds!!! Panasonic SC-HT520
It's possible that one of the fuses have blown on the inside. Sony DVD players are known for this (Models DVP 330, 360, 560) and there are many complaints about it. They give the "No Disc" or "C-13" error. I ended up searching the internet and found people that had the same issue. I found the fuse and went to the store to find I had to buy 5 fuses because they were not sold separately. I ended up just soldering the connection knowing that it may break again any time. It works now and has been working for 4+ years since it broke. I'm not a very technical when it comes to electronics. I was just mad that my DVD player broke after the warranty expired. I originally paid $400US for the Sony DVD player. Now I can buy Sony DVD players for under $100US.
Here's a couple of things to check:
http://www.ehow.com/how_2036283_replace-fuse-dvd.html
http://www.ehow.com/how_2036277_fix-error-dvd.html
Dec 29, 2008 | Panasonic Home Theater System System
Does not play DVD
You need to open top cover and look inside dvd player cd tray. Does dvd / cd disc spins or having loading problem because grrrrr seems mechanical problem.
Let me know your finding to guide you further.
Thank you.
Oct 25, 2008 | Sony DVP-NS575P DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Sony DVP-C650D Multi-disc DVD Player Logo
165 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
