Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb did not function when i insert it in the usb port their is no reaction
    Scholar:
  • 83 Answers
Try to connect it on any other pc or laptop if the problem remain same on them then it must be came some internal fault in your device. If it has warranty go to the device service centre to get a replacement of your product.
For further help or to thank me. Mail me on my email Ejaz89@live.com
Posted on Aug 06, 2010
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
When i insert a cd it says no cd
The receiver player lens needs cleaning. If your receiver is not used for long time or in dusty environment, such problems do occur. Even after cleaning the problem is not solved, then replace the player assembly. It is better to replace the assembly than to replace the pickup lens.
sonsunny
Jun 18, 2011 | Audio Players & Recorders
I have a toshiba laptop and broke my usb port by removing my printer usb. The computer worked fine until I restarted it,now I can only get a blck screen. It turns on buit it seems different. what can I do?
The USB interface is rugged and is designed to only allow a connector insertion one way. However, if a connector is upside-down and forcefully jammed into the port at an angle, it is possible shove it in and in doing so breaking the port's hardware. If you examine the port closely, you may see the part with four contacts bent such that the contacts are shorting to the metal shell of the port. Inserting a small piece of cardboard between the contacts and the shell may be sufficient to remove the short and so allow start up to proceed past the power up check of the USB ports. If this doesn't work, you can try pressing F8 repeatedly on power up to get into Windows safe mode menu where you can select different modes of start up including one without any drivers which may allow you to bypass the USB hardware problem. But this is a makeshift solution which only gives you very limited functionality. If the laptop is still under warranty, take it in for repair by a qualified technician. If the cardboard trick works and you don't care if one USB port is no longer functionable, then you can as an alternative just leave things as they are.
Mar 18, 2011 | Computers & Internet
I have a wireless keyboard and mouse and I can't type anything I changed the batteries and its acting like it has no power, nothing is working on the key board but the mouse is working. Thanks Tate
1) make sure your batteries are inserted correctly
2) make sure when you insert the USB sending unit into a port that the USB port is working
3) press the connect button on the sending unit and also the connect buttons on the bottom of the keyboard and mouse.
3) make sure in the system setup that USB is enabled.
var fctb_tool=null; function FCTB_Init_7207035e866d4ce295e256df09c8897a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_9fd4111ba11a4016a30810809c03e786(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Damaged USB Port
Ok I think the best method to "Fix" this would be to get your self a 4 - 5 port USB card, they are, real cheap, insert it into a spare slot, inside your PC, and install the drivers, if any, and use that one. And simply ignore the other one all together.
Feb 18, 2010 | Gateway Essential 400 PC Desktop
Asus P4P800-X USB Problem
Maybe your USB port on your computer is model 1.0 while the hard drive is a 2.0. That would cause it not to read it. Check your system information and see what model your USB ports are.
Mar 17, 2009 | ASUS P4P800-X Pentium Motherboard
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
108 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
