Question about Philips 42PF9630A 42 in. Plasma Television
Black Screen of Death.... I have a 2 year old 50" w/ambilight. Have audio but no video... problem was intermitant with no ryme or reason. Now I have not been able to get it to come on at all.
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
Posted on May 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Posted on Jun 09, 2008
SOURCE: I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV i
Hi Mikshanks,
I had the same problem with my TV. It was a horizontal problem with different shades of color, and black spots. I replaced my Upper & Lower Y-buffer boards. Your Y-sus board should be okay since it still powers on the screen. You should replace the Y-buffers Upper & Lower, and it should work. I hope this helps.
best regards,
Tyler
Posted on May 16, 2009
  • 541 Answers
SOURCE: Black screen no sound. Red and green standby/on
You probably have a bad power supply board or one of the x or y drive boards. It is hard to say because they all give this symptom. Usually power supply though.
Posted on Oct 13, 2009
  • 302 Answers
SOURCE: ambilight isn't working when I
Have you tried turning it on in the menu options. Navagate thru the menu there is a setting for on or off on the Ambilights.
Posted on Jun 08, 2011
Why my SEIKI 50" HD TV turns on indicated by th blue light. Screen is black and no sound. Only about 2 years old.
Do the flashlight test from the video below.
I'm having similar problem, the backlight is not working, I'm trying to find how to replace/repair it.
Aug 02, 2015 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
Philips 50" Plasma with ambilight
It sounds that there is some loose contacts to some connections to your Plasma display. Almost all plasma displays will have similar configurations to display circuits, will change only with the size of the screen. If you wish to get some details http://electronicshelponline.blogspot.com/ Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
Ambilight isn't working when I press ambilight on the remote control. TV is about 5 years old
Jun 08, 2011 | Philips Ambilight 2 52 in. Flat-Panel LCD...
I have green and red "speckles" that are very distracting within the dark/black areas of the picture. I upgraded software with Philips. No help. Nearest Philips repair is almost an hour away. TV is a...
Hi Mikshanks,
best regards,
Tyler
Apr 16, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Vizio 50p hdtv no video only audio
that would be your Ysus board and could also be your Zsus board, if you puchased it from costco over 1 1/2 years ago you can take it back for full refund
Jan 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Apr 13, 2008 | LG 50PX1D 50 in. Plasma Television
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
Philips 42PF9630A 42 in. Plasma Television Logo
216 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
