Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional low thump type noise from the speakers.
  • Toshiba Master
  • 8,457 Answers
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Posted on Aug 06, 2010
  • VinceMart Mar 10, 2011
    51h84 does not use a LAMP its a CRT rear projection tv! it uses CRT (picture tubes)
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Toshiba 27A51 TV won't power up, relay clicks twice
must be some of parts broken down. you have to check powersupply thorougly.
Dec 16, 2008 | Toshiba 32AF41 32" TV
My TV clicks, stays on, but still shifts to the left. I have a Toshiba 51H84 51inch
your looking to parts at the convergence area , either check for DRY SOLDER around the power supply area or replace the IC IN THE CONVERGENCE AREA starts with STK- ___ and numbers. try that , hope this helps
Apr 25, 2008 | Toshiba 51H84 51" Rear Projection...
Toshiba 51H84
convergence IC's need to be replaced
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
No Power
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Feb 28, 2006 | Panasonic SC-PM19 CD Shelf System
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
604 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
