Question about Philips Magnavox 27MS343S 27" TV
My Magnavox model # CT202MW8 won't power up. Have checked power to fuse, all good.
  • purrcy13 Aug 06, 2010
    Thanks for the help. Hopefully I can find the part I need.
  • 11,896 Answers
If the fuse is good, it is likely a fault power board or power supply depending on the type of tv. Both are very common failure devices. They provide power to the television set.
Posted on Aug 06, 2010
  • 2 more comments
    What's the recommende repair for this problem. Model # CT202MW8
  • Nate Stansfield
    Nate Stansfield Aug 06, 2010
    Testing of the power board will be necessary. There are capacitors on the system board that can overheat and burn out. A sure sign is a swelled up capacitor or resistor or burn marks on the system board.
    Each component has an imprinted number of it's voltage rating. An analog tester can be used to test if it is faulty. Partstore . com usually carries most brand parts.
    Can I replace the whole power board or do I have to replace just the bad component?
  • Nate Stansfield
    You can do it either way.
How do I set up Magnavox model ct202mw8 with no remote
Answered. Please post one problem once only by this forum.
Dec 14, 2014 | Televison & Video
Magnavox h2160mw9 power won't come on
I have 2 Magnavox h2160mw9 that won't turn on after power failure. I unplug, wait 15 to 30 minutes, then re-plug and the Magnavox h2160mw9 powers on by its self. I have to reset clock and any programing that was erased. Channels previously scanned remain okay. Hope this helps.
Jul 07, 2012 | Magnavox H2160MW9 HDD Recorder
My magnavox hdtv won't turn on no green or red light on the power butten no power at all
Start with the obvious. Is your TV plugged in? If it is on a power strip, does the strip need reset? If all is normal there, then unplug the set and take the back off. Check your fuse to see if it is blown.
May 17, 2012 | Televison & Video
My 50 inch magnavox plasma tv won't turn on. It
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.4_25_2012_3_37_55_pm.jpg
Apr 25, 2012 | Televison & Video
Need code for magnavox ct 202mw8 to program a
MAGNAVOX Codes: 004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
Mar 27, 2010 | Philips Televison & Video
No Power
check fuse most likely power supply shot shop at yard sale or pawn shop for new tv!!! :)
Jul 07, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox tv codes not accepted on dish remote
sorry to have to tell you that the dish remote is not universally compatible. There are after market remotes that are but they are pricey.
Feb 27, 2009 | Televison & Video
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
Philips Magnavox 27MS343S 27" TV Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
