I have a samsung 973v..the problem is that "there is no display"..what part of the monitor should i check..?
    Scholar:
  • 45 Answers
Cause:
  • Monitor failure
  • Video card or onboard video device failure
  • Driver conflict or improper driver installation
  • Power issue
  • Loose device connection
Resolution:
  1. Verify the computer and monitor has power and is actually turned on.
    • Not turned on? Well… turn it on. J
    • No power? – Make sure power connections are in and secure. Reseat them to verify.
    • Make sure their power bar is on. (If they have one.)
    • If the monitor still has no power, try it directly to the wall and another outlet.
    • Still no power on the monitor, RPL if in warranty and is the original monitor or Op sale a new one.
    • If the tower has no power, try step 5. If still no power see No power troubleshooting.
  2. Verify the connections are secure. Reseat them to verify this.
  3. Remove the monitor connection from the tower, check if the monitor self test appears. (If may take a few seconds) If it appears, the monitor is fine. If it doesn’t, bad monitor!
  4. Replace it if in warranty (and is the original monitor) or Op sale a new one!
  5. Does the owner have picture in POST (Power on Self Test) or in the Bios? Do they lose it as soon as Windows loads? (If the computer has no POST or Bios go directly to step 7)
  6. If they lose picture as soon as windows loads, boot to safe mode
    • Check for multiple video adapters, if there are two, try disabling the one the user is not using. (Usually a problem with onboard video overriding a video card).
    • If they are exactly the same try uninstalling one and rebooting. It might be a ghost driver.
    • If the ghost driver reappears after rebooting, try disabling it like it is a device. (Because it might be.)
    • If only one device is listed, uninstall the video driver. Reboot the PC and install the driver off of the driver disk.
  7. If the issue repeats, uninstall the video driver again, get the user into windows normally and Doc-express them the updated driver. Give the SR# and your audix. If this issue happens even with an updated driver, you are looking at service for a potential hardware issue.
  8. Do a hardware reset: Unplug the power from the wall and hold the power button in for 20 seconds. Try and boot. Check for onboard video as well as a video card. If the owner has both, try the onboard video. If it works. Check the device manager and try installing the video card properly. If it is installed properly, try disabling the onboard. Then switch it back to the video card. If the PC does not have both onboard and a video card. Proceed to the next step.
  9. Open the tower and reseat the video card. (Make sure the owner has the power off and unplugged. Also make sure they touch a metal part of the computer to discharge static (IE the metal frame or power supply)
  10. Still no video after reseating the card? It may be the video card or something on the motherboard.
  11. Remove the video card completely and try booting. Does the motherboard beep? If it does, the motherboard is fine and you should replace the video card if in warranty. If out of warranty, op sale a new one. If the motherboard does not beep, it may be a bad motherboard or something attached to it. (Note: Not all motherboards have beep codes, check the source!)
  12. If you are unsure if the video card is actually causing the problem, service may be the best option
Posted on Aug 06, 2010
Samsung sa850t monitor right half of screen is solid blue
I think your Display monitor cable damage, or may be your motherboard display cheap damage, or your display driver problem create.
First of all you check your display driver or reinstall driver. Sec think used external VGA card or check it. If not solved then your monitor display section damage. So contact good monitor technician.
Thanks..
Feb 03, 2014 | Samsung SyncMaster Computers & Internet
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
My monitor 17" Samsung 794MG CRT. Already Display setting 1024 x768 (Problem is Screen are Vertically Shake) Request you to give ideal settings for display of above monitor
This depends on your video card's capabilities. Try setting it to the lowest value, and then work your way up. If the screen is shaky, this may be a monitor problem. You may also try to set the refresh rate for the monitor lower, as this can be the cause of shakiness.
Sep 30, 2010 | Samsung 793DF 17" CRT Monitor
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Facebook display problem Samsung SynchMaster 713BM monitor
it must be the drivers your using for the monitor. Have you checked the pins connector are all straight. as bent pins will cause this.
http://www.howtodrivers.com/model502115.html
webpage link for drivers
AndystUK
Vote me happy
Aug 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor No display
1. Power is comming or not.
2.Check Horizontal Transistor.
3. Disply cable. 1,2,3, pins & 13, 14 pins continuty.
4. Filament supply , drypoints in neck board.
5. filament supply diode, capacitor.
Oct 23, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
