I have a magnavox model 42mf439b lcd tv and it seems to be frozen...the power is on to both the television and the cable box but the tv screen says digital television in the bottom right corner and the green power light is blinking two to three times per second. the only way to turn the power off is to unplug the tv
  • 12,061 Answers
This is a fairly classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, this usually happens due to a power surge strike etc.
With this switchmode symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else. Anyway thats my 10c worth.
www.p4c.philips.com/files/4/42mf439b.../42mf439b_f7_pss_aen.pdf
Posted on Aug 06, 2010
How to fix a 1/2 black screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
1/2 of screen turns black, what can I do to repair it?
You may have a faulty T-con board or bad connections at the screen sockets,the contacts on the flexible circuits can be cleaned with an eraser but be carefull not to bend or in any way damage these ,the result will be the need to replace the whole set..
Le
Oct 13, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
42mf439b/f7 Magnavox LCD TV How to replace invertor modual
Oct 08, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
Magnavox 42MF439B TV stuck in stand by
First thing you can try is:
1. Unplug it from the power cord and wait a few minutes.
2. Turn it on (when it's still unplugged from power)
3. Plug it in power and try to turn it on again
Let me know if this fixes your problem or we need to look for other solutions.
Jan 05, 2014 | SNK Magnavox 42MF438B/27 42 in. LCD TV
The screen on my Magnavox model 42mf439b/f7 will only display a white screen. What would I need to fix this problem?
Displays white screen, means, the absense of video signal. The T'Con board should he checked. If you wish to get more details, check this site linked. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 19, 2013 | Toymax Magnavox 47MF437B 47 in. LCD TV
Magnavox 42mf439b/f7 screen will not turn on
Set need through check up. It sounds that the digital processor board also need service.
Apr 17, 2012 | Televison & Video
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Where is magnavox lcd t v made
They are pretty much the same and are made under licence by Funai probably in China
Jan 29, 2009 | Philips Magnavox 27MS343S 27" TV
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
