Question about Symantec Backup Exec Sbs Std 12.5 Full Version for PC
Error code 80042314 while backup & backup failed
Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Mar 17, 2014 | Computers & Internet
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
IDE device fail error code 0F00;133E
This error code means your HDD is failing. You need to backup any important data and purchase a replacement hard drive.
Feb 27, 2013 | Dell Inspiron 6000 Notebook
Back up error.....i need more help please
check out this link for the solution.
http://www.pagestart.com/win7br0x8100003301.html
Dec 28, 2011 | Acer Aspire AX3400U2022
Windows Backup fails error code 0x8007005
Try;
1.) Loggin in as an Admin on the computer.
2.) Check if D:\ is not write protected.
Mar 24, 2009 | Microsoft Windows? Vista Home Premium...
Erecovery management
use an external usb cd or dvd burner
Mar 08, 2009 | Acer Aspire 5720 Notebook
I got the below error ... is it possible tot ake my backup from the HDD?
A 0146 error means that the hard drive has a failing sector, and the drive will need replaced. If it's operable, then back everything wanted or needed up, because it will fail completely if it hasn't already.
Aug 26, 2008 | Dell Inspiron 6000 Notebook
Treo 650 Hotsync Problem
Many factors can influence the synchronization process. you will have to go step by step from this: http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(25004) Good luck.
Jan 04, 2006 | Palm Treo 650 Handheld
Symantec Backup Exec Sbs Std 12.5 Full Version for PC  Logo
781 people viewed this question
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
