Question about Northstar Pressure Washer 3000 PSI
Engine will run for 1 minute then shut off with a cloud of white smoke out the exhaust. i remove and cleaned carb. float is free not binding no improvement
  • 700 Answers
This symptom can indicate several problems, white smoke is usually indicating water in the system, as this is air cooled honda motor, therefore it is not coolant, check oil and check if there is water present in oil sump or in fuel tank.
Water from fuel tank can be easy drained, with fuel, replace then as well fuel filter and clean again carby. add about an ounce of methylated spirit adn fill gas to full, start engine and check if problem still present.
If this did not solved the problem, check oil for presence of water.
Water can seep to oil sump through trans, and as water pump is located directly on the shaft, simmer bearings may load water under pressure to the crancase. If necessary, repalce bearings and seals.
Please let me know if this was correct advice, or you did find other reason for that white smoke.
Oil is usually burning bluish, fuel not fully burned is black.
Hope that this will be just condensation in the tank.
Posted on Aug 06, 2010
  • bzet1820 Aug 16, 2010
    sometime it is dishearting... there is over 60 views of this advice, and not even one rating or comment... I know all backyard mechanics are more familiar with tools than with computers but do give us some credits and at least say: It works! or: You were wrong!
    It is encouraging us to gie helping hand to others if we see that this what we do is at least appreciated!
I have a Predator 4,000 generator that wont stay running. I followed all recommended instructions before trying to start it. It ran first time for about two minutes and died.same thing every time.
sounds like a fuel flow problem.Pull the fuel line off at the carb and see if fuel flows well when you turn the gas on.If the fuel is flowing to the carb,you will have to remove the float bowl off the bottom of the carb and check for fuel flow through the needle and seat which the float controls in the carb.If fuel flows well through the needle and seat and the float words well without binding, next is to clean the main jet which may be plugged.Ethanol in the fuel these days can cause problems in these areas.ALWAYS shut off the fuel in all small engines and let the carb run dry when storing small engines for any length of time.
Feb 07, 2018 | Cars & Trucks
I have a 18hp kohler it starts and ruins for 5/ 10 seconds and them shuts down and there is a cloud of white smoke
Air cooled engine ok ,
When the engine shut off did it white smoke out the garden it could be the head gasket
Low compression and it won't start poor compression and it might start but run poorly stall easily and white smoke produce because of unburnt fuel escaping into hot exhausts and vaporizing
Jul 03, 2016 | Garden
Honda gx620 on golf cart occasionally bogs down & blows enormous cloud of white smoke from exhaust.gas getting in oil also.runs great until this happens
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
Feb 26, 2014 | V-Twin Horizontal OHV Engine with Electric...
My Toro has been great! But today saw white smoke from exhaust. Checked oil & added some. Few minutes later blew clouds of white smoke & air filter dripping oil. Did I just blow a head gasket?
Sounds more like the engine has been tipped, oil can then enter the air filter box via the engine crankcase breather, allow the engine to run with the filter removed until the smoke clears, refit a new filter if it is a paper element type and try again.
Apr 13, 2013 | Garden
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Flooding Carburetors,
Sounds like the carbs are gummed up,and the floats are stuck. The carbs will have to come off,be thoroughly cleaned,and the float levels reset,and synchronized.
Aug 29, 2012 | 1991 Suzuki VX 800
Engine is blowing whit , then blue smoke from the exhaust , then the motor shut's off ???
I have had this happen on my Murray riding mower (Briggs engine. The problem turned out to be a stickling float/needle valve in the carb flooding the engine. . Tap the carb with a small hammer and it usually frees up, but it will probably return. I also found that with the engine off, that fuel would overflow the cab, into the engine and into the crankcase. I had to put in a shutoff valve in the fuel line.I rebuilt the carb, but the problem returned after a while. low quality carb.
Dec 04, 2017 | Garden
Onan generator not running
recheck, reclean,and rebuild carb possible had moisture in fuel and carb --white smoke--but sounds like float and carb still gummed up
Feb 15, 2010 | Watts Onan Portable Generator - 4000 ,...
Aquired a 1985 gpz600r cleaned carbs new fuel plugs and battery started with a big cloud of smoke (been sat for 7 years) runs lumpy for a minute then dies fuel leaking from 3rd carb have i got to strip the...
First take that 3 rd carb off, the needle and seat is stuck in the open position, the float may be rubbing on the inside of the float bowl cover, or the float setting is out of adjustment (too rich) either way the fuel to the bowl is not shutting off as it fills, the needle and seat must be forced shut by the gas filling the float chamber raising the float and pushing the needle up into the seat. Sometimes the float has been compromised put it in a cup of gas to ensure it floats and is not a sinker. reassemble and check for the fuel over flow if it still over flows your problem has not been solve this issue must be adressed first for the bike to run right otherwise that one cylinder is going to foul and the bike will never run right.
Dec 08, 2009 | 1989 kawasaki GPZ 500 S - GPX 500 R
Engine oil was throw in the gas tank, engine would not start.
You will need to clean other parts of the engine aswell, especially if it was pulled over with oil in the tank. First of all buy some carb cleaner. Now remove the bowl from the bottom of the carb by unscrewing the central bolt (10mm) underneath. You can leave the float and needle in place. Now spray the carb clean over these parts and also direct some up the jet in the middle of the carb body. Clean and replace the bowl. Now remove and clean the spark plug. Before refitting it pull the starter a few times to throw out any oil that might be sitting on the piston. It may also be wise to remove and check the exhaust (12mm) for oil. When it is all refitted the machine should start after a few pulls. It will probably still have some oil in the sytem so don't be alarmed if it smokes (white) for a couple of minutes. Once this has all burned off you should be fully operational again.
Oct 28, 2008 | Honda Garden
Northstar Pressure Washer 3000 PSI Logo
488 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
