Air Conditioner tripped circuit breaker
Bryant outdoor a/c unit model 561CJ030-E
serial 1204E15932
Tripped dual 20A breakers today.
When the breaker was reset, I could hear humming from the unit.
I spun the fan with a screwdriver blade, and it slowly increased speed, but never got anywhere near full speed.
I've shut off the breaker again until I had some idea what to do next.
The circulation fan in the furnace unit is still working.
Is there anything I can do to troubleshoot and fix it myself?
  • Dave Roehrman Aug 13, 2010
    Yes, it was beyond my abilities to troubleshoot. Turned out to be an 8-inch cylindrical attachment under the outer cover of the cooling unit. Thanks
    Genius:
  • 1,478 Answers
It could be a number of things. Anything from a weak breaker to a nearly dead A/C. My guess is a basic service/maintenance call will take care of it. When was the last time you had it serviced?
Depending on the age of the house (breaker box), breakers do wear over time and become more resistive. When you turn your AC on, it gets very hot and that's what typically causes breakers to trip. The breakers trip when they get hot due to overcurrent, or just old age. My personal experience was that my box was so old (1968), the busses feeding the circuit had corroded to about 1/2 the size and basically lit up like a lightbulb when the AC was on, causing the breakers to trip. I had to remove the box. First, a heat pump should have exactly the same cooling capacity as a regular A/C unit of the same tonnage. You should really have your unit serviced yearly to be sure it is working at maximum capacity and efficiency. As to the breaker tripping, it is hard to diagnose without being there, but from what you describe, it sounds more like a problem in the electrical service to the unit rather than a problem with the unit itself, but there are many possibilities, and unless you have some basic experience with electrical work, it is best left to a professional. Your best bet would be to call an A/C company.
Take care.
Posted on Aug 06, 2010
I have a carrier air conditioner 38TKB024. About 15 years old I think. Accidentally ran it with the cover still on after the winter. shut it off after about a day when I realized. Went to try it the...
You probably just blew the fuses or tripped the circuit breakers. There may be fuse right beside the unit in a box with a door on it. The fuses will be in a cartridge inside the box. You will need to change them both unless you have a ohm meter to check them. Also check your circuit breakers. The will more than likely be in your main circuit box. It will be two joined together, probably 20a or 30a. Trip them all the way back and then forward and try the unit again.
Jun 11, 2011 | Carrier KCA101P Air Conditioner
No power to ac unit
Check the breaker for the unit or check to see if the disconnect by the unit in the attic has fuses that may be blown.
If the breaker is tripped or the fuses blown, then check to see what caused them to blow...
heatman101
Aug 01, 2010 | Bryant 463AAC008BA Air Conditioner
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Circuit Breaker Tripping
either the circut breaker is getting weak,or the compressor is pulling to much power .
Aug 16, 2009 | Heating & Cooling
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
42 degrees outside and air conditioner is blowing hot air!!
turn the unit off at the main circuit breaker or isolating switch, to reset the unit it has tripped out on its high pressure safety. to stop this problem happening on 42 plus days hose down outdoor coil with water
Jan 29, 2009 | Heating & Cooling
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
230 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
