Question about Health & Beauty
We have a QUINTON Q710 ECG which I am told has a bad "brain" (pcb?). Can this board be replaced? I have been able to repair my own big screen, can solder, etc.,. Is board replacement relatively simple on this? I have looked for sources for a new board and this is proving very difficult. Does anyone know this repair process? Any leads for a parts source? Part #? Many thanks, Donald
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
There is no printing
hi,
may be ur machines thermal printer head have some problem. also check the paper u have inserted. it should be a wax paper or chemical paper.
ok
Dec 24, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
Screan looks like it is out of synk
Good Day,
You a problem with the Hyper Board, MVPU14, there are about 10 Caps that are bad. This Board is not availible. This Board must be repaired.
Now, some Companies can repair it, most will send it off to get rebuilt. It will cost about $350-$450 for repair.
Call an Authorized Service Center for repairs.
Good Luck, big IRISH.
Caps that go bad, they are CM mounted: CZ52,CX261, CX270,CX230, CX178, CX221, C514, CX241, CX670 &CX541, aND VERY HARD TO REPLACE WITHOUT DOING DAMAGE TO PCB.
Dec 09, 2009 | Toshiba 50HDX82 50" Rear Projection...
I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
My tv wont turn on. I have a toshiba regza 47hl167 and when it is in power saver mode it will not turn on have to unplug it and plug it back in till it finally comes on then change the power mode off then...
yes he is right.the digital main pcb is the brain of the tv and has the microprocessor which
controls unplugging the tv and plugging it back in.you are resetting the micriprocessor which is part of the digital pcb.
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
Resoldering of Q710
Hello, I am sorry about your issue. I suggest having the receiver serviced. Thank you, Onkyo USA
May 07, 2017 | Onkyo TX-DS575 Receiver
Onkyo receiver audio problem
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1 button, press Speaker A.
4. You should see "CLEAR" on the display for a second and the unit will go on stand-by mode.
5. Turn on the unit again and check if sound is back.
Hope this helps.
Mar 23, 2008 | Onkyo TX-DS575 Receiver
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
