Question about Gateway FPD2275W LCD Monitor
Dell 172FPb problem
I have read several...no, many threads but I have not found an answer. Maybe missed it.
The power indicator is on steady. black screen. No computer connected. I hold a strong light up to the LCD and can see the test pattern moving as usual.
I am not sure what this means...simply bad backlight?? I believe there are 2 (there are 4 connectors). I would doubt both are bad. Is this likely the dreaded 4 C5707 xistor problem or something different. How does one know if the Cclf's are bad or not??
Thanks.
  • alexjent Apr 28, 2008
    There are a lot of cap on the board...
    Guess I'll just send it in to lcdrepair.. For $20 they'll fix it.
    Thanks,
    Alex
  • 558 Answers
Blown capacitors on the inverter card they are fixable if you can solder
Posted on Apr 28, 2008
Innotab says connection failed http=404 but seems that I am connected but won't let me finish the set up
go google and type in-- what does http=404 indicate-- there are several good explanations available including wikipedia
basically while you think you are connected , the url that you use cannot be found on a server
any way read all the different sites and maybe you will find a pointer to the answer
Dec 30, 2015 | Toys
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black. this has happened before and I can't remember how we fixed it.
Dell monitor E177FPc - light comes on green but immediately turns steady amber and screen is black? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Nov 15, 2010 | Dell E177FP LCD Monitor
My printer is not printing black ink, only in color. black ink cartridge is new. model #A940, service tag 5D53Z31, express service code, 11678555485. can you help?
Try this:
Go to Google Maps, select one and print it out. Does black work then? (On mine it does)
If you try to print an e-mail with both color and black fonts, are the black ones missing from the print? (On mine, the black letters are missing)
How about a scan which contains both color and black features? (Again, both black and color works for me)
And finally, if you scan an all-black font document after hitting "copy...black", you get nothing....but do the same thing after selecting "copy...color"...and it'll print the black.
I'm sorry I haven't found the answer as yet, but maybe if you try some of these little experiments I did this morning, then it'll catch someone's eye and we'll both have a solution (which may cost more than a new printer!
Jun 12, 2010 | Dell A940 All-In-One InkJet Printer
Dell 1501 vios2.6.2. reads missing operation system..then after 18 seconds it shutdown..pls..help... anybody has many opinion to fix it i appriciate it very much. tnks..
Missing operating system errors generally indicate a hard drive read failure. This could be for several causes.
  1. Hard drive failure (Run diags on the drive, if you get an error code, then time to replace)
  2. Software corruption (Too many possible causes to list
  3. Virus
So run Diags Fn+ Power, see if HDD passes diags, if it does, then boot to your windows CD and go to recovery console in XP, (Repair My Computer in Vista/7) in recovery console, run the command CHKDSK /R
If that doesn't resolve, then try a repair install of windows;
http://www.fixya.com/support/r3874510-find_information_windows_installations
Jan 12, 2010 | Dell Inspiron 1501 Notebook
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Monitor stuck in Power Save Mode
yes look like your nvidia run out of juice you can look at nvidia 7200 le or maibe 8200 gs that will be a reasonable price / quality grafics cads for a upgrade of the 6800 thanks
Oct 19, 2009 | Dell XPS 400 PC Desktop
Dell Dimension 2400 with steady amber power light and diagnostic lights of ABC green and D off. What could be the problem?
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
I have the same problem D830
Seems to me if it ran normally until powered down that the motherboard would have to be functioning, no? It's a boot or startup problem, but there are all kinds of hardware and software issues that could cause that. Have you tried booting into safe mode or last known good configuration by pressing F8 as it boots up?
Try going to Dell support and enter your service tag # and see if there are any service bulletins or advisories for your laptop, then maybe search the Dell forums for reports of the same. If the motherboard was an issue on your model, you'll find some forum posts about it.
See also Dell support for your boot problem here.
If you get it booted up again, you might like to take a look at the event viewer and device manager and see if there are errors or warnings posted that indicate software or hardware problems on your system. Also consider running the Dell diagnostics utility (see here) to check the system health. And run chkdsk to scan the hard drive for corruption. (instructions here and here)
Malware removal protocols I'd recommend as a check here.
Good general troubleshooting for windows here and startup here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 10, 2009 | Dell Latitude D830 Notebook
What signal is sent over the center pin of the power adapter?
the problem isn't in the psu - it's in the laptop. The centre pin supplies a trigger voltage with a simple carrier which tell s the BIOS about the power characteristics of the unit. Missing that signal, the BIOS assumes that even though there may be enough power to run the laptop, there may not be enough to charge the battery - a situation that, on lower power PSUs, can lead to damage to PSU and/or laptop. That's a safety feature that it doesn't attempt to trigger the charging circuit. The most likely reason for that trigger being missing is the (very poorly-designed) PSU interface having become disconnected from the rail. The socket needs replacing.
Dec 04, 2008 | Computers & Internet
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Gateway FPD2275W LCD Monitor Logo
327 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
