Question about Whirlpool WTW6700TW Top Load Stacked Washer / Dryer
Is there a reset button, washer has no power blown breaker
  • Whirlpool Master
  • 12,061 Answers
NO reset. Please remove this from the Power immediately.
When a Breaker is blow, this is VERY serious and may put voltage on the case...
it is my professional opinion though that everyone should get their units serviced by their manufacturers approved service center.man, contacting a head office, of your unit & getting an approved service center.man is just SO important, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". This way, at least, you'll know weather to repair or replace.
Service manual below.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/68589b9b3ebd030c8525736100667580?OpenDocument
Self help how to troubleshoot and repair washers.
http://www.washerhelp.co.uk/diy-repair-help.html
Posted on Aug 06, 2010
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
Karcher problems
Check to see if there is a red button on the motor. If there is it is likely an electrical reset button. Push it in and check to see if there is power. Try a different power outlet as you may have blown the electrical breaker on the power supply from the building.
Aug 04, 2014 | Karcher Garden
My washer has no power at all.... what do i do about it.. how can i fix it
Hi from retired Englishman in SW France, Frid afternoon, 14:20
Is there power at the socket? Try with another device- a kettle for instance.
If there is power, I would suggest you will need a service call to you washer ;-0(
If there isn't power to the socket, check the main fuse/breaker. If the fuse has blown or the breaker has tripped replace fuse, reset breaker.
If there is a (serious) fault with your washer the fuse will blow again/ the breaker will trip. Once again you will need a service call ;-0(
Sorry I can't help further.
Best of luck,
John C
Mar 04, 2011 | Fisher and Paykel IWL12 Top Load Washer
Our GE Dishwasher just stopped all together. No power..nothing. All the fuses seem ok. Not sure why it just died. WIRES seem to be in tact..etc.
Ia the fuse blown? or the breaker tripped off? Must know if these are the problem. Plug in other small appliances in outlets in the kitchen to see if power is there. If not go to breaker box(usually in garage) check your sticker label and reset horizontal switch(curcuit breaker)back to on position. Note; sometimes these breakers can look like there on, if not sure switch off and on again. If you have power to outlets( INCLUDING WERE WASHER IS PLUGGED IN) you'r all set. Check the outlet where washer is plugged in, you may find a breaker built-in to it. The reset will be between upper & lower outlet, if so this needs to be pushed in.(most have tiny red button) Keep in mind the outlet might be defective. Never work on electrical untill you are sure that you have the right breaker OFF! If not sure call a professional! Good luck, best regards.
Feb 01, 2011 | Dishwashers
My K5.20M power washer won't start. Am looking
Make sure your extension cord is able to provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Now that you have the correct power supply you will notice the GFI Test and Reset buttons by the power washer plug. Plug the power washer into the power receptacle which has live power. Make sure the power washer is off and then push the reset button located on the power washer plug until you hear a click. The GFI should be reset and you can now turn on your power washer.
Jul 26, 2010 | Karcher Garden
Whirlpool GHW9300 Washer does not come on
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Aug 06, 2009 | Washing Machines
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Power surge and breaker went off, turned it back on and washer comes on but not the dryer, is there a reset button
The dryer is on a different circuit as it is 240 volts. Look in your breaker box and find the breaker for it (it should be tripped half way). Turn it completely off and then back on. There is no reset button for it. Make sure the plug is securely pushed all the way into the outlet.
May 12, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't turn on
Begin by checking to be sure the outlet where you have the washer plugged in has power. you may have blown a fuse or popped a circuit breaker. If no power, either replace the fuse or reset the circuit breaker by turning it all the way off and then all the way on.
Feb 28, 2009 | Washing Machines
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Whirlpool WTW6700TW Top Load Stacked Washer / Dryer Logo
98 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
