Virus I was working on a reliable website (theknot.com) when my computer froze. It would not bring up the task manager (ctrl+alt+delete), so I restarted it. Then it would not re-start. It said my BIOS was not installed and then the screen said PRB installed 2...done (or something similar). If I wait long enough, the screen advances to Windows "starting up screen" but it never loads. DELL support said (after I tried to ensure it booted from the hard drive), that I'd have to restore factory settings and lose all my data. Is this true? Is there another option to save my files?
  • Georgia B
    Georgia B May 11, 2010
    It's not a virus. It's a driver conflict in Vista usually video. Did you recently install the Vista SP1 update?
    Guru:
  • 1,342 Answers
Assumed solved. No reply to clarification request.
Posted on Jul 26, 2008
Why won't my HP laptop let me type anything?
Whichf HP laptop? Is your PC hung up? What version of Windows?
Usually you can do a CTRL-ALT-DELETE and this brings up the Task manager. If your keyboard has a proper driver loaded, it will show you the Task manager screen. Select - start task manager. then look at the list of Processes. There should be atleast 9 processes running. Sometimes a virus in your system can lock your keyboard just to irritate you.
Jul 13, 2014 | Intel Dot Station (INTC300AIO) PC Desktop
I have lost ALL of my taskbars!! How do I get them back?
A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
  1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
  2. On the Applications tab, click New Task at the bottom right of the window.
  3. Type explorer.exe, then click OK.
If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
If that doesn't work, then try this:
  2. Go to the Processes tab.
  3. Click on the Image Name column header to sort the list alphabetically.
  4. Find all explorer.exe processes - select each, then click End Process for each one.
  5. On the Applications tab, click New Task at the bottom right of the window.
  6. Type explorer.exe, then click OK.
Are you using snagit, try to uninstall it and then check if you still get the errors. If you donot use snagit then there would be another error.
If you cant access control panel use the "Windows Key+R" on the keyboard which opens the run dialog and type in 'sysdm.cpl' which opens the control panel.
You could also try to restore you windows using System Restore and select a date of the backup when the computer was working well.
Make sure you do a complete virus scan with a good antivirus with updated virus definitions as it could be a virus too.
Jan 21, 2011 | Computers & Internet
My compaq mini 110 was infected with THINK POINT VIRUS. i downloaded a malware scanning program which seemingly worked for about a day...with an abundance of pop ups and self restarts. as i researched...
Hello
The re-installation of windows is however recommended, but you can try with follwing procedure to remove Think point Virus:-
1. Restart your computer in SafeMode - After Power-On the computer, just before Windows start, press F8 - From the selections, Select SafeMode
2. End ThinkPoint Process - Press Ctrl+Alt+Del from the keyboard to open Task Manager - Go to process Tab - Select 'hotfix.exe' and click on End Process - Close Task Manager
3. Remove Registry entries that the threat added. You MUST BACKUP YOUR REGISTRY FIRST. - Click Start > Run - Type in the field, regedit - Navigate and look for the registry entries mentioned above and delete if necessary
4. Delete malicious files that the threat added: - Base on the given location above, browse and delete the file - If no location is given, click Start>Search> and search for the files. - If cannot be deleted, press Ctrl+Alt+Del to access Task Manager, see if the file is running in the process. If it is, select the file and click End Process. Perform file delete again.
5. Scan computer with Antivirus Program - Update antivirus program - Scan computer and delete all detected threats.
Hope it will helps, if so do rate the solution
Good Luck
Dec 15, 2010 | Compaq Computers & Internet
My internet windows i was using froze and i cant exit out how do i close them
ALT + F4......to exit. if this not working then ALT+CTRL+DEL....then end task
Dec 05, 2010 | Computers & Internet
Hi! I have think point virus since 2 days ago and I did all what you have said(Malwarebytes? Anti-Malware, ad.aware) but after that my internet it´s not working, I did in safe mode with networking,...
After the ThinkPoint screen loads push the command CTRL+ALT+DELETE quickly. This will bring you to task manager. Open the tab called Processes, find the process hotfix.exe and end it. The rogue program should be gone now. Next, you need to bring your Desktop and taskbar back. While in task manager go to File and select "Run new task". Type explorer.exe in the open box. This will bring back Windows explorer. More detailed instructions are given below. At this point you should be able to download anti-malware software which will remove ThinkPoint.
http://deletemalware.blogspot.com/2010/10/how-to-remove-thinkpoint-uninstall.html
Oct 20, 2010 | Compaq Computers & Internet
How do you delete virus without bein on administrater and no mone
antivirus.com
Housecall
it is TrendMicro site for free housecall tells you how to
Jul 31, 2009 | Dell Inspiron 1300 Notebook
Create a new task
Start Windows Task Manager (Ctrl+alt+delete or right-click on taskbar -> task manager) Then click "file" in the top left corner and press "New Task(Run..)"
Jul 23, 2009 | Computers & Internet
Stays at 100% Cpu usage, I have E machine W3307
there's a good chance you have a trijan, assuming you have an antivirs programme, run it in safe mode (F8 on startup and enter using safe mode), use the administrator account to log into windows, and then go to my computer icon, right click>properties>system restore tab, then turn off system restore.(viruses and trojans have a back up in system restore)
Run anti virus programme, restart pc then turn system restore back on
If you don't have an anti virus/spyware you can get a free download with free updates here, (choose the avg free download)
Sep 09, 2008 | E-Machines Computers & Internet
Serious TaskManager Problem!!
Task Manager can be disabled by 2 main ways..
[1] Either there is a virus on your machine--
[2]Or It was manually disabled.
--The 1st solution is to get an anti virus which is up to date and run a virus scan to delete the viruses that maybe present.
--The second solution is that on your START MENU, click on "run".
On 'run' type "gpedit.msc"..
Under the "User Configuration" , click on " Administrative Templates"..
Then you double click on "system" .Double click on "Ctrl+Alt+Del Options"... Double Click on " Remove Task Manager" and click on "Disable"... Click on "Apply" and "Ok"
Your Task Manager should now work !!!
Jan 03, 2008 | Computers & Internet
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
The Ctrl-alt-del short cut to the Task Manager is not on the MobilePro 900. To bring up Task Manager on the MobilePro 900, hold the "Alt" key and then tap the task bar with the stylus simultaneously. A menu with "Task Manager" and "Properties" will be displayed, select Task Manager.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Computers & Internet Logo
David Payne
David Payne
