My MX-2300N Printer/Copier/Scanner is having a copying error. The main screen constantly says "Remove paper from center tray, yet there appears to be no paper in the ccenter" tray. I have reset the machine twice to no avail. I do not know what else to do.
    Scholar:
  • 45 Answers
Please verify that no printer paper is jammed or partially fed into the printer. If you have one or more pieces of paper stuck in the printer these will need to be manually removed before the printer will print again.
Posted on Aug 06, 2010
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
Sharp copier MX-2300N cutng imaige when copying
Check registration ( timing of paper start from alligning roller with the scanner unit start ), or there could be a problem with the paper feed system ( Paper getting physically stuck / releasing late )
Jan 16, 2013 | Sharp MX-2300N Color Copier
F3-12 Paper tray desk trouble
check the paper trays ensure guides are set correctly and check behind the draws no paper stuck behind, also remove any paper from draws which is considered storage paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 14, 2012 | Sharp MX-2300N Color Copier
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
There is an error on the screen which says "remove paper from the paper tray" and there is no paper to be removed. What can we do?
G'day, I know the answer from much investigation. you see I had the same problem "Remove paper from center tray". This fault occurred after a weekly wipe down of all moving parts to prevent the print rollers from becoming "Sticky" (with residual toner). I could not work out this fault I read the above answer and spent at least 40 minutes pressing prox switches and messing around with tray setup, and nothing the fault still appeared. then I decided to read the manual, and... Guess what NOTHING on the specific "Remove paper from center tray", but what I did find is that the "Center tray is non other than the Output Tray, you know, The Spot where your new fresh printed paper comes from. If you get a torch or light and look inside you will see two leavers (one double leaver and one single leaver). The single middle leaver is your problem, it senses to see if the "center tray' is full so that it can stop printing to avoid a problem. this center leaver comes unattached, all you need to do is clip it back into its home position. Straightaway your problems will go away. Cheers McHaggerty
Aug 30, 2011 | Sharp MX-2300N Color Copier
i have a sharp m7001n that says to remove paper from center tray cant find there is not a finsher on it also says tray 1 and 2 is prohibited.can you help
Sep 20, 2010 | Sharp MX-2300N Color Copier
How do i use the auto configuration facility on a sharp mx-2300n. I have saved the configuration on the server but when I connect to this printer over the network, I only get Factory Defaults under User...
While at the printer settings page of the copier on your PC under printer configuration there is an automatic configuration tab. Once you press this it will ask you to check the boxes with the arrow . The paper is set determined by the copier itself. You may need to check your copier settings to make sure it detects the correct paper in the tray. Also it is not recommended to install this way mainly because if the customer doesn't want to print color they are not able to change the printer condition settings at the individual PCs. So individual install is recommended.
Oct 17, 2009 | Sharp MX-2300N Color Copier
"Load Paper" screen wont go away. Is loaded with paper!! Help!!
Goto the job status and select the print job that is waiting.. To the right, select details and select the paper size you want. Identify the job because you will want to make sure the settings in that document are set to the correct paper size and type.
Dec 03, 2008 | Sharp MX-2300N Color Copier
135 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
