Hi. We have a dvd/vcr combo DRC8300N, we have tried to play a dvd, but the player says that there is disc error. It then explains that the disc is either dirty,incompatible format, or wrong region. We have tried several different dvd's including one which cleans the video reader,nothing will play. What should we do to correct this problem. Thanks. David
  • 758 Answers
The main reason, there are many, for this failure is either a weak laser diode or badly aligned optical pickup. This stops it from reading the digital information on the disc and causes the player to think the disk is damage.
I hope this helps
Please rate accordingly
Thank You
Computerrep
Posted on Apr 27, 2008
  • Jean Sintulaire Apr 27, 2008
    I wouldnt recommend you to get it fix because it might cost you more money then replacing it...
  • 88 Answers
If you have try with a clean up CD your laser lens is probably defficient you have to go to fix it to a specialist, sorry for the bad news
    Genius:
  • 3,587 Answers
Hmmmm...that is usually due to an internal defect in the DVD sensing digital electronics..did this one ever play DVD/s
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Apr 28, 2009 | RCA DRC8300N DVD Recorder/VCR
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Unit will not record DVD's
remove cover clean burner eye a little toilet paper,put a little grease on linear bearings, very little using a toothpic use verbatim dvd rw discs from cdw inc. 1x4 speed
Jan 22, 2009 | RCA DRC8300N DVD Recorder/VCR
Rca DVD/VCR COMBO SAYS NO DISK INSERTED WHEN IT IS
open your vcr and locate the lens.then get cotton budds and clean the lens manually.
Sep 02, 2008 | RCA DRC8300N DVD Recorder/VCR
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Dvd player combo
uncompatable disk?if not try cleaning the lens of the player by using a cd/dvd lens cleaner...the cd thing with the two brushes stuck onto it...with some cleaning fluid
Apr 25, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
