Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
I am needing to locate the back light inverter board can any one e-mail my a pic plz. I have a samsung hp-t5054 plasma 50 inch. zpalsrok@yahoo.com thank you.
  • 11,361 Answers
Plasma TV does not use backlight inverter board like the LCD flat panel does.
http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+HPT5054
Posted on Aug 06, 2010
I have a Samsung HP-T5054 have no picture but have sound can u please help.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 03, 2017 | Samsung Televison & Video
I own a samsung 60 inch plasma model pn60e550 2 yrs old after running and shutting off when you try to start you get only sound no picture
Jan 17, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung hp t5054 light comes on but it has no pic, sound and does not click when plugged in
Check that all cables are intact and plugged in correctly. (VGA, DVI, Antenna etc.) Did you place batteries correctly?
There might only be one button that turns the TV on/off (usually a red button in the top of the remote).
Jul 06, 2014 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
Samsung 50" turns off and clicks
Since its a Plasma or seems to be you got this in the wrong area-a glitch on the site here often does this---if a flat screen set--Plasma or LCD post the question with model number in the text under Flat screen Televisions so a expert can assist you.
Dec 16, 2012 | Samsung HP-T5054 Widescreen 50 Plasma HDTV...
I have a 50 inch hp-t5054 samsung, it gets vertical lines (green and blue), that run in front of the picture, and vary according to what is playing; sometimes not at all.
The problem with this kind of trouble is that it can be the main board, even the power board or another board causing this.
Trouble shooting requires testing voltage, waveforms with a scope and schematic and signal generator---if only happens from time to time guessing can get expensive.
I had one of these (same brand) under mfr warranty---did it for a few minutes each day or sometimes longer----Samsung Tech assist said change main board and power board and ship to the customer---I advised them problem not there all the time--the reply was if it comes back we will deal with it then.
So much for technical assistance and solid troubleshooting.
May 16, 2012 | Samsung FPT5084 50 in. Plasma HDTV
I own a 50" samsung plasma, model hp-t5054. Last
you have a defective module on your board,about 1x1 inch black have a technicien appraise only if the service is free
May 29, 2011 | Samsung FPT5084 50 in. Plasma HDTV
50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Jul 28, 2009 | Samsung Televison & Video
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Blue light on bottom of tv
This problem can be caused by a bad main board. I have only seen it one other time though. If the unit is under warranty I would have the board replaced, If not, it is fairly expensive and you may want to live with the light. Hope this helps
Mar 02, 2008 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
252 people viewed this question
Jerry Greenberg
Jerry Greenberg
