Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Spark Gap Lamp Driver Problem? Sony LCD TV?
My LCD TV has been getting progressively worse - instead of turning on - it will give off a buzzing sound and go to standby mode. (without turning lamp etc on) For the last few months I have been able to finally get the tv to turn on and when it does - it works fine. However, now it will not turn on at all. It will attempt to turn on several times and then the fan will turn off and the red light will flash 5 times. I have removed the lamp (sylvania) and reset it - but no change. (also- the lamp indicator has NOT ever lit up - so I believe the lamp is still good - when the tv USED to turn on - the tv worked fine).
Through my research, I believe it has something to do with the spark gap to the lamp driver board. The buzzing sound appears to be the machine's attempt to send power to the lamp - but "it ain't a workin'!"
I have heard that several people have this problem with this tv but Sony has not issued a recall.
Is there anything I can do that will not cost $200 + for a repair call?
Thank you so much!
  • Sony Master
  • 8,617 Answers
Lamp driver error 5 times - Lamp driver is faulty. The symptom will be no picture or sound . Repalce the lamp driver.
Posted on May 23, 2008
When you turn the tv on it makes a buzzing sound 3 different times and remains black
Sounds like you just have a bad lamp. The buzzing sound would be the spark gap on the ballast trying to fire the lamp. Access door for the lamp is on the side in the rear. A few screws and pull it out, you'll prob find that the glass has broken inside. New lamp part# is TS-CL110U and around $170
Bill W
integrityhomeworx.com
Mar 09, 2011 | JVC HD-52Z575 52" HDTV
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the back....is this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Picture comes and goes every few minutes on the rear projection LCD. I just recently installed a new bulb
How recent? That lamp should have a 30 or 90 day warranty. From what you are describing, the lamp is a dud. The cycling occurs when the lamp burner gap becomes too large after warm up. Listen closely to the sounds the TV is making when it is trying to bring the picture back up. Is there a buzz or gurgle sound coming from the lamp area? That's the TV trying to ignite the lamp. Get a new lamp or your money back for the one you installed. I hope this was of some assistance.
Apr 13, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
The tv made a "pop" sound and turned off, now when I turn on the tv the screen is black and there is a buzzing sound, Is the a bulb issue?
Yes Lamp is Bad and Buzzing sound is Ballast board spark cap arking. Lamp is a XL-2100U Fox has them for $109.00 other companys want $215.00 for it
1-800-227-5369
Dec 31, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
My sony kdf e55a20 cuts on and off, but the lamp indicator never turns on
Order a new bulb, easy to replace, just read the manual. In the meantime, go into Settings and change the Power to Power Saving, instead of Standard. Your bulb will work fine until the new one arrives.
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
My Grand Wega KF60WE610 has no picture and has a buzzing sound when turned on. If left on the green light blinks and the buzzing sound may or may not occur again. Can anyone diagnose this issue?
That buzzing sound is this kind of Tv LCD Projection, is most likely a issue with the ballast (only if sound cames near the lamp) you can check that just follow the cables that are connected to the lamp, take out the back cover of tv, and keep pushing the switch cover (if not tv will not turn ON). and check if that sound comes from the only board connected to lamp. if it does, you are going to need a ballast very soon.
Jun 25, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung Dlp HL-R7178w not turning On.
If all 3 leds blink, it can be the lamp, ballast (lamp driver), color wheel, or dmd board (all are engine parts = engine failur). its usually the lamp, but you can listen to troubleshoot. when it turns on, you will hear the fans come up (humm..airflow noise), then you will hear the colorwheel (high pitched squeel.. it will come up to speed) and then the ballast will fire up the lamp.. if the lamp doesn't fire, you will hear the spark gap fire (a 1 second buzz noise indicating bad lamp).. the gap will fire 3 times, they tv will then retry again and again until it shuts off and kicks out the error. this power up path will help you listen to find your problem. i can assist further.
Jan 08, 2009 | Samsung Televison & Video
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
245 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
