Question about Alpine Car Audio & Video
I have a 2010 international prostar eagle big rig, the o/e radio sux, I want 2 install an alpine with sirius and blue tooth I'm having a hard time finding either a wiring harness 2 work, or the schematics 4 the truck so I get the and - correct on the speakers, I don't want to damage them they r ok 4 now. Can u help?
Go here for wiring harness for your stereo, they also have anything else you need for any heavy duty truck stereo
http://www.bigrigstereo.com/harness_plug_and_play.html
Posted on Mar 03, 2011
Alpine 9886 with sirius interface
This problem sounds very sirius. Sorry, couldn't resist, but "siriusly", the song alert feature is supposed to be something you select yourself, so it locates a particular song whenever it is played on the service. Do you recall setting this?
Are you using the Alpine KCA-SC100 tuner or another?
I would try resetting the radio too.
Dec 13, 2013 | Alpine Car Audio & Video
My Sirius radio, factory installed in a 2008 VW R32, won't activate, even after a "soft boot". Sirius mentioned having the dealer do a "hard boot". What is that?
I hope this post finds everyone well who is having difficulties with Sirius Radio's trouble shooting advice to reactivate service. I tried to reactivated my service and had experienced all the problems that everyone has had on these forums. This is what works. It took me a lot of phone calls and I want to get the word out to everyone (regardless of Make, Model or Year of Vehicle)
First, a soft reboot does nothing and there is no such things as 'reseting' the electric system in your car. Second, there is no such thing as a 'hard' reboot to your sirius radio. All a soft reboot will get you is cold legs when you have to hold your car door open for 30 seconds in the middle of winter. All a hard reboot will do is cost you a lot of hard earned money at the dealership. Best case scenario is that your dealer replaces your entire radio and charges you $500+.
WHAT YOU NEED TO DO: Call Sirius Customer Service and ask for Technical Support. Explain to them you are having difficulty obtaining an activation signal. The technical support technician did the following (and it was the most intelligent thing I heard from Sirius)
1. Go turn on your Sirius Radio and tune to Channel 184.
2. The technician put a "dummy" ESN in on my account, refreshed and then re-entered my original ESN back into my account and then re-sent the activation signal. **NOTE** Make sure you write down your original ESN number before you ask to have them do step #2....there is no way for them to recover your original ESN if they put in the 'dummy' ESN and refresh.
3. Within 10 seconds of putting doing step #2, my Sirius Radio said, "Updating Channels" and worked great.
Takeaway from My Experience: I believe that once you let your Sirius Radio Service relapse and/or do not renew your subscription, a signal/frequency is sent to your radio to block service or reactivate your service. The problem must be an internal issue on Sirius where the only fix to stop this signal is to completely clear (or zero) out your original ESN, enter a dummy ESN, refresh and then re-enter your original ESN and then send the activation signal.
I hope this helps everyone.
Sep 02, 2010 | Sirius Satellite Radio Receiver
How to hook up a sirius radio to a alpine ada105 car stereo do i need any interface cables or anything else the stereo is sat radio ready
you shouldnt have to purchase any other cables to hook up sirus however somtimes due to the changes in the manufactor weather it be xm or sirius you may come across your radio not interfacting with the package you bought you might want to check the manufacture about this sirius 99 percent of the time will hook up to most JVC Alpine, Kenwood, ECT but you need to look at the back of your reciever at your connections on the back you should have in output and or input for for either aux in the back such as for a cd changer or in your case that will be used for your sirius hook up. My names Josh and i hope your able to get it figured out.
Mar 05, 2010 | Alpine CDA-7892 CD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius Stiletto 100 - can't record as of Jan 1 2010
Hard boot fixed it... (removed battery, put it back in... shoulda tried that a long time ago...)
Jan 05, 2010 | Sirius Stiletto 2 Portable Satellite Radio...
I bought sirius radio for my husband who drives a truck. He is having trouble keeping a signal. The truck is a large four-car hauler and we wondered if placement of the antennae was the problem. Even...
They make a special antenna that mounts on the the mirror mount for the big rigs. You need a big antenna, as the regular one isn't going to work very well on a big rig. Many full service truck stop stores have the big rig antennas. Try that first. You might have better luck with XM than Sirius too,
Dec 28, 2009 | Sirius Satellite Radio Receiver
Alpine equalizer wont work
to have them work you have to connect the yellow wire to constant 12 volt power,and the red to blue and white wire coming from the radio if you dont have a blue remote wire on the radio connect it to the accessory of the car wire that power the radio
Nov 04, 2008 | Alpine ERE-G180 11-Band Car Equalizer
Alpine wont pick sirius up
make sure you are set on the correct frequency. both the device and the radio.
Jul 22, 2008 | Alpine CDA-9883 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
1,024 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
