Question about Daewoo DWC-150C Air Conditioner
My daewoo dwc 0520rle ac unit is makeing a sloshing noise when i installed it i didnt pull a plug or hose pleaes notify me if i was supposed to or is a prosess that happens that humidifys the air thank you gary
3 Suggested Answers
SOURCE: clicking noises
make sure thisis abnormal because sme a/c are noisy in operaqtion but if not check mat fan motor bearing need lubrication or replacement
note if still in waranty let dealer check
Posted on Sep 04, 2009
hvac1960
  • 2133 Answers
SOURCE: 1. What is the
The style of keeping the model number changes co to co. But you can read from your unit BTU. 12,000 BTU is equa to 1 TR. The room temp should be located near by return air grill.
Posted on Dec 02, 2010
I have a Daewoo DWC-0520rle air conditioner and the remote does not work. Put in new batteries and still nothing happens. I live in Hawaii is there any place here that I can get a new remote?
Before you shop for a new remote, check the installation of the batteries. It's quite easy to make a mistake with the placement while replacing batteries.
Aug 24, 2013 | Daewoo DWC-052C Air Conditioner
My daewoo air conditioner model: Dwc-0520rle stinks when i turn it on , why ?
could be something dead in the casing and also check the filter is clean
Sep 15, 2011 | Vacuums
Hello, I have a 5300 BTU, 4.8 amp window air conditioner from Daewoo. I just hooked it up and after 15 minutes it has water sloshing around inside it making loud sounds. I tried level, the 1/4 inch fall...
Hello, that sound Is normal usually when humidity is high. The evaporator coil sweats when the humidty is very high and the fan spashes the condensate on the condenser to evaporate it. Now if the unit has a knockout hole you can use it but you must use a hose attached to it so it drains properly. But the sloshing sound is normal during high humidity.
May 31, 2011 | Daewoo Heating & Cooling
1. What is the BTU rating of the DWC-0520RLE 2. Where is the room temp sensor located
Dec 02, 2010 | Heating & Cooling
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Ac wont come on trip plug lights for 1 sec then goes out.
QUESTION?? WHY DAEWOO?? DID YOU EXPECT ANYTHING ELSE?
Jul 08, 2010 | Daewoo DWC-056CL Air Conditioner
I purchased 2 0520RLE airconditioners at cosco one has no hardwar
Contact the manufacturer explain your problem and they should send you the hardware you require.
Jun 12, 2010 | Daewoo DWC-052C Air Conditioner
Clicking noises can be heard from my new Daewoo dwc-0520rle Air Conditioner when its running. Is there a way to fix this?
Sep 04, 2009 | Daewoo DWC-052C Air Conditioner
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Daewoo (DWC-056CL) Air Conditioner
You don't have to remove the polystyrene that is inside the unit. It is part of the construction of the unit. It is part of the molded construction.
Jul 02, 2008 | Daewoo DWC-056CL Air Conditioner
Daewoo DWC-150C Air Conditioner Logo
124 people viewed this question
Top Daewoo Heating & Cooling Experts
Steve
old fart58
armandog07
armandog07
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
