SOURCE: thermal printer wont print...
Are you using thermal paper? Do you have the correct side up !
SOURCE: how to make change to print on thermal paper
On the front panel of the printer:
Press SETUP/EXIT
Press NEXT/SAVE until you see a setting call PRINT METHOD
Change the setting from THERMAL TRANS to DIRECT
Press SETUP/EXIT
Press NEXT/SAVE to make a permanent save
Hope that helps.
Testimonial: "great thanks!!!!!"
SOURCE: I have just loaded a
hello aleisha.... Sometimes in this camera, that first black protective sheet does not pop out of the camera like it should. Instead it sticks or jams and has to be manually removed. In order to fix without exposing the entire roll of film you will have to do it in the dark or in a darkroom, if you have any access to one. You will have to open up the camera and remove the packet of film, then remove that black sheet or clear it of any paper jam. Joe
Thanks for choosing Fixya!
SOURCE: fuji Finepix 50 fd
How are you connecting the camera? Is it a cable that came with the camera? Can you put the media card in a multi-reader and DL the pics?
Is the camera still in automatic? (green camera logo) Or is it in scene, night shot?
If you put it to automatic, and it won't change anything, I'm afraid your camera is defect. Contact a certified Fuji repair centre, but before you send it in for repair, ask what it will cost you. because camera's are becoming cheaper and cheaper. Don't pay more for a repair than you would pay for a new camera.
