Casablanca Fan Advan?Touch W-62 Remote Control Logo
Posted on Sep 12, 2017
Hi, I have a casblanca Advance Touch Remote Control Model W-62. The display works and I can see all the controls. However, it will NOT turn off the FAN nor the LIGHT. It doesn't seem to be transmitting directly to the Fan. Again, the display works and my husband checked that it is in fact transmitting. However the fan will not stop or the light turn off. What can I do?
3 Related Answers
MN_Jack76
Jack Jr
  • 46 Answers
  • Posted on Oct 17, 2009
SOURCE: fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Anonymous
  • 57 Answers
  • Posted on Apr 01, 2010
SOURCE: I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
caroldon
  • 17130 Answers
  • Posted on Feb 22, 2011
SOURCE: Casablanca Fan/Light Remote (Versa Touch #W-42)
Possible that the drive to the IR LED is low and it can be due to poor output from the driver or a weak IR LED.
Please check this link below for some tips.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Point your remote to your camera in the phone and see if there discharge is good enough . If not check the voltage at the IR, check if there is break in the printed circuit board or a possible open circuit from a SMD resistor...use a multimeter to check continuity.
Look on the PCB using a good magnifying lens to confirm.
2answers
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
Remote Control Not working
JUST GOOGLE THE BRAND OF THE REMOTE AND YOU WILL FIND A CODE FOR IT.
3answers
Need remote code for samsung 5.1 home theater surround sound model#HWC560S
Welcome to Fixya. I would like to know who is the provider of the remote so we can provide you with the code. example: AT&T, Comcast or etc.
Please provide the information needed to be able to fix the issue.
Thanks
Require Remote Control Set Up Codes
I have a slingbox and I am based in the UK. I need help from someone to create a binary file I can use within the slingplayer software to control my sharp TUTV502H remotely....
I can get most of the buttons working using code 44 of code 62, hope this helps.
There is another issue I am experienceing in relation to controlling the TUTV502H remotely which is outlined in this post http://www.hifi-remote.com/forums/viewtopic.php?t=11625&sid=fd5131f04cda102df8771e07d138f64b
It sounds as though someone who knows what they are doing might be able to help...?
Thanks in advance.
The receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
1helpful
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
We have been given a new remote control but the volume does not work and when we try to turn over it works for ma minute then stops working altogether
Hi, I think you have a something (an object or liquid) inside the buttons that is causing a short on the remote control board. When you turn the remote control over, the object does not touch the remote control board, this is why the remote control works. I would turn the remote control over and just tap on it firmly a few times. if that does not work, then you might use a blow dryer on the remote control Key. Let me know the outcome so that I can further assist you. Thanks, Mike H
2answers
Bose LCD Touchscreen Remote Control
try bose main support e mail @ https://www.bose.com or contact # @ 1800-905-2138
Top Casablanca Fan Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
