Question about Kenmore Oasis HE 27082 Top Load Washer
Our Kenmore Elite Oasis model 2804 type 581 is about 2 years old. Still working on this problem. (We've been working around it by just turning off the cold water to fill the tub with hot water.) There is power to the cold solenoid when Hot wash is selected. I replaced the timer module, and STILL getting power to the cold solenoid when Hot wash is selected.
  • Dave Roehrman Aug 06, 2010
    Thanks for narrowing down the possible culprits. I appreciate your quick responses. My wife loves this washer (& dryer), even when she has to turn the cold water off to get a hot wash.
  • 11,896 Answers
Have you replaced the selector knob? That could be the case if the solenoid has already been replaced and no one interchanged the water lines.
Posted on Aug 06, 2010
    I have not replaced the Cold solenoid. Is there a way to test it? It reads about 500 Ohms while disconnected. It appears to operate when it gets power, and shut off the water when power is removed. Trouble is that it always gets power whenever the hot solenoid gets power, even when Hot Wash is selected. Could it still be bad?
    If I decide to replace it, how does it come out of the manifold assembly. I don't want to break something trying to remove it without knowing how.
  • Nate Stansfield
    Nate Stansfield Aug 06, 2010
    500 ohms is good. And from what you describe, it works properly. Sounds like the selector switch or control panel is causing it to be activated at the wrong time.
Kemmore elite oasis model # 110.28042701 type 581washing machine not turning on.
Make sure it is receiving power. Having confirmed this what works and what does not. Resubmit your inquiry with specifics so help can be rendered.
Nov 23, 2015 | Kenmore Washing Machines
How to bypass lid lock control on kenmore elite oasis type 581 washer model 110.28032701
there isn't any way to bypass this type of lid switch as in the old 2 wire type lid switches,as the 5 wire type lid switch you have has to be connected to the control board located behind the control panel,it has to see the lid is closed and sends a magnetic signal to the control board to start the wash cycle
Oct 29, 2012 | Washing Machines
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
191 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
