Question about E-Machines eMachines Monitor E15T4
I'm trying to adjust the appearance of my screen. The problem is that it has a "washouted" look. Either the resolution is off or the brightness needs increasing. I have tried several ways to change this but the instructions for this monitor are simply not specific enough. The monitor controls consist of two arrows on the right hand side, a menu button and an auto fig. I have followed the instuctions on the disk(page 13) but with no success. I've also accessed my "properties" option by clicking the right side of the mouse on the desktop. Is there a direct and easier way to change my resolution and/or color? Thank you, Robert Jenkins(please direct answer to -rjenks245@hotmail.com- or i'll wait for your rreply in this window. thank you
    Genius:
  • 1,066 Answers
What kind of graphix card do you have?
if you right click on your desktop and select personalize>display settings (vista) or properties>screen resolution (xp) and then properties>advanced settings. flip through those tabs, you may find adjustments depending upon your video card.
Posted on Aug 06, 2010
How is adjust my screen size back to the way it was so that I can use scan controls on the right
To change your screen resolution. , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
Change your screen resolution - Windows Help - Microsoft Support
https://support.microsoft.com/en-us/help/14108/windows-7-change-screen-resolution
or try this link.
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+is+adjust+my+screen+size
Dec 16, 2016 | Computers & Internet
On my laptop screan it gon a bit dak and i ned help 2 fix this
Hi , I think your laptop brightness settings had been changed. So try this to increase and reduce the brightness , contrast. Select start-> control panel -> appearance & personalization -> display . There you will have options like Adjust brightness , Adjust resolution etc., on the left side of your window. You may adjust in this way.
May 20, 2014 | Samsung HCM422W 42" Rear Projection...
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    MONITOR VT17N71, SN C0542C0739 I CANNOT GET THE RESOLUTION THAT I THINK THE SCREEN SHOULD HAVE. I'VE TRIED ADJUSTING THE BRIGHTNESS...BUT IT'S ALWAYS TOO BRIGHT. I'VE TRIED ADJUSTING THE CONTRAST,...
    Hi.
    Just a general suggestion.
    Are the graphics drivers loaded.
    (Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
    Jan 06, 2010 | Soyo Computers & Internet
    Screen adjustment
    Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
    • With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
    • Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
    1.
    In Control Panel, open Display.
    2.
    On the Appearance tab, click the Effects button.
    3.
    In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
    If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
    If the projected image is not rectangular, try one or both of the following:
    • Make sure that the projector is perpendicular to the viewing screen.
    • Raise or lower the projector.
    If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
    • Adjust the brightness of the image.
    • Check the projector lens to see whether it needs cleaning.
    • Adjust the sync and tracking on the projector.
    Sep 09, 2008 | Panasonic Videoprojector PT-LM1E...
    My screen has dimmed but the cursor remains normal
    I think its just like driver problem or you adjust the color in under advance button in the screen and resolution setting
    takecare
    Apr 28, 2008 | Computers & Internet
    Unable to adjust the brightness of display screen
    bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
    Dec 22, 2007 | Dell Inspiron 9400 Notebook
    E-Machines eMachines Monitor E15T4 Logo
    148 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
