Question about Vizio P50HDTV20A 50 in. Plasma HDTV
I have a vizio VPHDTV20A. A 50 INCH n where can i find some fuses. ET8AH250VP
Alliedelec.com
Posted on Aug 13, 2010
Is their a software fix for vizio 50 in uhd for the color
Just go to the colour calibration settings on the Vizio 50 it should recognise if you're in UHD and have setting for it. If it does not then google software updates for it and see what pops up. Good Luck.
May 06, 2015 | VIZIO P502ui B1 50 Inch Ultra Smart
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
I have power and sound but the screen is black ... i have read that it could be a fuse ... how do i access the fuses or where are they located on the tv ... it is a vizio 50 inch plasma P50HDTV20A
Hi the picture on a plasma TV is controlled by the Zustain board. You have a bad Zustain board. Their are two on your TV so you have to figure out which one is bad to order it. Most of the TV the bad one will have a bad fuse or it will not heat up like the otherone. You can always replace them both also. you can get parts fro this TV at www.interliquidparts.com
Jun 13, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
WHERE IS THE FUSE ON THE 50 INCH VIZIO SCREEN
It is on the power supply module, and it could be surface mounted, it will be mark with a (F) on the module.
Feb 16, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
50 inch plasmaty will not come on
POWER SUPPLY,,, CHECK FOR BAD FUSE,, AND IF THE FUSE IS GOOD CHECK CAPACITORS. WICH MOST LIKELY THAT WILL BE THE PROBLEM. ONLY THOSE TWO CAN BE THE PROBLEM... IF THE FUSE IS OKAY JUST REPLACE THE POWER SUPPLY... YOU CAN GET ONE AT TVPARTSANDMANUALS.COM
Jan 13, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
670 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
