Question about Toshiba E-Studio 3511 Color Copier
Error c446 - Toshiba E-Studio 3511 Color Copier
  • 30 Answers
Hi how are you this is jack hear in pk ....(jack_pak@hotmail.com)
First Step copier ON 0+8 press 400 press start Baton.
copier show one value ...5or 6 or7.. any xyz then you press 0 and enter... copier off... simple copier ON....
Thanks
Best Regards,
Posted on Aug 12, 2010
How to go to 08-400 and reset the value to "0"
1. Step (i) Switch the machine off
2 .Step (ii) Press and hold 0 & 8 simultaneously.
3. Step (iii) Switch on the machine
4. Step (iv) Enter the code 400
5. Step (v) Press start button
6. Step (vi) enter the value 0
7. Step (vii) Switch machine off
8. Step (viii) Switch the machine on to check for the error
Feb 08, 2016 | Toshiba E-studio 281c Copier
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Call for service c446
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine. When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Jan 29, 2013 | Toshiba E-studio 281c Copier
No picture white line going horizonally across screen
You have bad capacitors in the vertical deflection. You will need to replace capacitors that are near and next to the vertical IC. These models very, but they all seem to have the problem you have. You did not specify a particular model. But in general you will look for under sized electrolytic capacitors. They are, in my opinion, too small to carry the load in the vertical deflection. Pay attention to the caps and there locations. Once again this model may be a little different than the one I have repaired. C417 is 50 volts at 4.7 Mf, C446 is 50 volts at 22Mf, C441 is 50 volts at 100 Mf, and C513 is 50 volts at 1 Mf. You will note how tiny these are, and so, please check all of the smallest ones with an ESR capacitor checker. The caps and locations I give, are enough to correct the problem you describe. I have repaired several of these. All are similar, and may have slightly different locations in the models, but they seem to be of the same values. Thanks for asking and show all hands of support!
Apr 21, 2011 | Sansui 32" TV
Error code C446. What does this error code mean?
Its basically a heater abnormality. Try and not use your printer continuously. Give it ay least a minute break after avery 100 prints!
kc
Mar 18, 2011 | Toshiba Office Equipment & Supplies
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Toshiba Studio 351c Call for service
You need to post the error code (top right hand corner of the screen
Jun 11, 2009 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 3511 Color Copier Logo
255 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
