Powers up and then goes into protection mode after about 4 secs
  • 443 Answers
Begin with disconnecting ALL the speaker wires from the back of the receiver, then power up the receiver to see if it continues to go into "protect mode", if it DOESN'T, then you know that one or more of the speakers or speaker wires has a electrical short in it / them!
Closely inspect all the speaker wires to see if there is any bad, worn, bare spots or anything that looks not right, if so replace ALL speaker wires!!! If all wiring looks good, then you may have a "BLOWN" speaker which is actually a dead electrical short, and the the speaker(s) will have to be replaced!
If all speakers are in good condition, then your receiver or one or more of the components that you have connected to it has an internal short and will have to be repaired or replaced.
GOOD LUCK !
Posted on Aug 06, 2010
Testimonial: "thank you for that I certainly will try that.I'ts a much loved unit and I've had it for about 10yrs (no problems)"
Protection mode on HK Festival 60
The power surge may have killed the power supply on the unit
If you have home insurance , see if your policy covers it
If not, it would be too costly to service ( Over $100)
Dec 21, 2013 | Harman Kardon Audio Players & Recorders
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
This is a qsc plx 3002 power amp. when i plug it in the green light shows it want to power up but does not. instead it makes clicking sounds like it does when it goes into protection mode.within 10 sec....
You are correct, it is in protect mode, usually caused by an overload.
You need a QSC Service department for repair.
Sony STR-V444 suffer, like all amplifiers, from dry joints caused by vibration. Resoldering the output section on both machines may indeed repair them.
Feb 13, 2018 | Audio Players & Recorders
Turns off after 4 secs or so....From Green to Red,
probably one of the surround channels is blown, thats why it goes into protection, meassure output transistors with a ohm/diode meter if thers no shortcut in the base to collector
pauliesbouth
Aug 25, 2008 | Denon AVR-1905 Receiver
DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Jul 21, 2008 | Yamaha RX-V461 AV Receiver
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Powers on 5 sec then powers off
if it goes off even with no sound, system is put on stndby protection mode. something wrong with your output section. busted power output xtors of IC.
Mar 17, 2008 | Audio Players & Recorders
109 people viewed this question
 Grubhead
Grubhead
