Question about Panasonic CQ-R155 Cassette Player
The tape deck auto reverse setting keeps switching the tape's sides over and over. How can I fix this?
Why does my deck not play in reverse?
check for a broken rubber band for the rewind spindle
bands available from Jaycar in packs
Nov 08, 2015 | Audio Players & Recorders
Not all cd tapes play clearly out of 12 tapes ,4 sound ok ,8 soundwrak
Are these all commercial pre-recorded tapes? Or are they tapes that were recorded at home? Is the tape deck one that the tape loads in from the short side and must be flipped around to play the other side....or is it one that the tape loads in with the tape facing in and is auto-reversing? Pre-recorded commercial tapes should work on most machines without problems. Home recorded tapes can be a problem, especially on the type of deck that the tape must be swapped over to play the reverse side. Many users use C90 or C120 tapes to home record. These tapes are thinner than normal tapes and are prone to getting overly tight and then can break and/or stretch. This causes jamming in the deck and distortion of the playback.
Jan 18, 2015 | JVC Car Audio & Video
Although I placed both ends the necessary sensing foil ,when choose auto-reverse with my Akai GX-636 RtR only the right tension arm sense the foil and blocks without reversing.When in recording mode it...
I'm pretty sure the auto-reverse is NOT supposed to work during recording. What would be the point since it only records in one direction?
And I'm pretty sure there's only one reverse sensor, usually to the left of the heads and not necessarily on a tension arm. The sensor foil is supposed to be on the non-oxide side of the tape so it will adhere better and never contact the heads.
This picture of a GX-635 shows a typical transport ...
http://www.oaktreevintage.com/web_photos/Reference_Photos/Akai_GX-365D_Front_Face_Off.jpg
There's a knob for how the auto reverse. Is it set correctly? I believe infinite forward / backward play is possible if you have the knob set properly, a sensor foil on the tape and the tape counter set to 0000 at the beginning of the recording.
May 12, 2011 | Audio Players & Recorders
When i push play on either deck - the tape starts to move and then the tape deck switches the tape's direction continually
If you observe the sprockets in the cassette you'll probably see they're not turning. That would indicate a broken belt or something mechanically common to both decks. Deck logic probably interprets the lack of sprocket rotation as end of side and auto-reverses. Take it to a shop.
Mar 19, 2010 | Technics RS-TR272 Single Cassette Deck
Just want to know whether there is a way to get a tape to auto reverse on the dual tape deck, and, what is the "OSD" button on the receiver for? This is an old Denon D-1250 shelf system. Thanks,
OSD = On Screen Display
Auto Reverse is a built-in feature of any tape deck. It would have a button that looks like > for forward and < for reverse; and probably a switch that sets the mode for automatic or manual reversal at end of tape.
Feb 24, 2010 | Audio Players & Recorders
Older Teac cassette decks
I had an Aiwa dual deck and by the way your describing it, when you select Cont. Play press play on one deck then play on the other. I am not sure if there's a difference as to which you start with. When the first deck is done playing both sides, the unit will goto the second deck and play both sides, then back to deck 1.
Jul 01, 2008 | Audio Players & Recorders
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
Dual tape deck inoperable
clean the rubber pinch rollers with an alcohol swab. the tape is not getting required "grab" on these rollers and not pulling tape. the auto reverse is an attempt to rewind the tape because of confusion with no tape movement.
Nov 12, 2007 | Yamaha KX-W321 Single Cassette Deck
Panasonic CQ-R155 Cassette Player Logo
94 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
