Question about ViewSonic VP211b 21.3" LCD Monitor
I have a viewsonic vp211b monitor and when I try to hook it up to my dell it doesn't do anything at all. no pictures on the screen nothing. The power supply is fine as I am getting a green light on the front of the monitor that also flashes orange at times.
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
I have repaired several of these Viewsonic VP211b monitors. In every case, the problem was a blown fuse on the inverter board. There are two fuses, F1 and F2. Either one can fail. The fuses are located on either side of the CN1 connector. These fuses are 1.5 mm long, 1.0 mm wide and 0.5 mm high (Case Style 1206). They have the letters FN printed on them. The N is for 2 Amps and the F is for Very Fast Blow.
The fuses were made by LittleFuse. The replacements were purchased from Newark Electronics. Part number 64R8010. This part number is the Fast blow 2.0 Amp (not the Very Fast blow), but they work fine.
Troubleshooting hint:
The screen is illuminated with fluorescent back lights. Those back lights are powered by the inverter. If everything is working except the back lights, you should be able to see a faint image by shining a bright flashlight into the screen.
I have a viewsonic vp211b - viewsonic-vp211b-0r4mioey1rjkalfz5jos2omp-2-0.jpg
Posted on Mar 04, 2015
Suricatta
  • 92 Answers
SOURCE: ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
or
Have you connected your monitor with a new power cord ?
Best Regards!
Posted on Jun 29, 2009
FixinFax
  • 3085 Answers
SOURCE: Need Power Supply for VP2130 Viewsonic Monitor
try ebay, i've found a few for Samsung monitors there.
Posted on Aug 04, 2009
  • 20 Answers
SOURCE: hi, my viewsonic va912b monitor disply 'no
Try this first. Unplug the monitor power. Let it set for a few seconds and then plug it back in. This corrects this problem most of the time. If that doesn't work, try doing the same thing with the video cable. Disconnect it from the PC and then reattach it. The connections may have gotten corroded and are not making a good contact.
Hope these help you. because beyond that you are looking at either replacing the monitor or the video card.
Rich
Posted on Dec 16, 2009
budmrtn
  • 11361 Answers
SOURCE: ViewSonic VE170b 17" LCD Monitor Faulty power
You need to check the fuses on the backlight inverter board, also the logic board may be damaged by the AC voltage.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Dec 02, 2010
SOURCE: my monitor blureed
Both suggestions are good starting points, but it may be an internal fault.
Other steps to try: check the signal cable -- wiggle it a bit at the PC end and at the monitor end, while watching the image on the monitor. Any change? If you have issues when moving the cable at the PC end, you may want to try shutting down the PC and disconnecting the monitor. Then clean the pins on the monitor's connector with 91%+ isopropyl alcohol and a cotton swab (make sure no cotton is left behind). let dry and try again.
If none of this make any difference, wait for the monitor to go dim. Then, gently smack it on all sides. If the image clears up or changes, there is likely an internal bad connection. Do not open the monitor unless you are familiar with all safety precautions involved.
I have the same monitor and I was having a similar problem. Turned out, there was a cracked solder joint on the signal board at the back of the CRT plus several more questionable ones.
Posted on Dec 07, 2010
I turned the brightness all the way down on my vp211b - not thinking that I would not be able to see the OSD to turn it back up. How can I do a factory reset without being able to see the OSD?
PDF Manual at the link below.
http://www.viewsonic.com.au/support/manuals/files/LCD/Series%20P/VP211b-1%20User%20Guide%20English.pdf
Press MENU (Button 1)
Then DOWN Arrow followed by ENTER (Button 2)
Then DOWN Arrow followed by ENTER (Button 2) and you should be in the Brightness Menu
UP / DOWN Arrows should now change Brightness
Aug 01, 2011 | ViewSonic VP211b 21.3" LCD Monitor
Monitor only works for short period of time
These monitors have a problem of poor quality capacitors. Loss of power as the monitor heats up suggests bad caps. Marginal caps perform worse at higher temps. I repaired a VP211b in 2006 by replacing C52 and C53 on the power supply board. These are 680 uF 25V. I replaced them with 1000 uF 25V because that is what I had on hand. The monitor worked good until now (2015).
Like yours, it would lose power as it heated up. This time the big capacitor on the power supply failed. It is 150 uF 400V. Replacing the bad cap fixed it. These electrolytic caps usually swell when they go bad. The top will curve upward. There may be some brown material leaking out. Any swollen cap should be replaced.
May 31, 2008 | ViewSonic VP211b 21.3" LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
I have a viewsonic optiquest monitor Q20WB and buttons not workin
Sounds like that monitor has reached the end of the road. I would recommend purchasing another monitor, other than view sonic. Purchase a Dell..they are great!
May 13, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
Iimj9 sonic tft - lcd monitor goes out after 3 seconds
You should remove power for a few min then hook up and try again.electronics sometimes need to be reset after any fluctuation in power. Good Luck
Jan 26, 2009 | ViewSonic VX910 19" LCD Monitor
Viewsonic VP211b No Power
I have fixed several of these.
The most common fail on the Viewsonic VP211b is a blown fuse on the inverter board. Check fuses F1 and F2. These are Fast Blow 2.0 Amp surface mounted fuses, case style 1208. Available at Newark Electronics, part number 64R8010. They are located on either side of connector CN1.
Jan 15, 2009 | ViewSonic VP211b 21.3" LCD Monitor
ViewSonic VP211b 21.3" LCD Monitor Logo
123 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
