Question about Whirlpool GH8155XJ Microwave Oven
Our power was flicking on and off - All of the sudden the microwave turned on, the light came on, and the vent came on! The microwave had the lock sign on the door panel and started cooking for 60 minutes. When we open the door the microwave stopped, when we closed it it would keep cooking. I could not get it unlocked - any ideas on how to fix it? Its very dangerous if this happens while we are not home.
  • 229 Answers
Have tried to unplug the unit for a minute in order to reset unit?
Posted on Sep 14, 2017
  • 9098 Answers
SOURCE: Microwave won't work
F6 usually means a fault in the controller or keypad. You could try to unplug it for several minutes, then plug it back in. If it still fails, maybe you or a friend can disconnect the power cord, unplug the keypad strip internally, then plug the power cord back in and try it with the keypad still disconnected. If it does not fail again, you have a wet or shorted keypad and can dry it or order one. If it does fail again, the control board is bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: Sorry I didn't get to answer this before the bogus answer was posted. I've been tied up and away from the PC.
Posted on Apr 10, 2007
  • 19396 Answers
SOURCE: Whirlpool Talent Microwave The microwave starts
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Posted on Oct 08, 2008
  • 9098 Answers
SOURCE: Cook Light Stays On and Microwave doesn't work
You're close.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel,
we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 21, 2008
  • 1214 Answers
SOURCE: Whirlpool microwave cook light turns on but oven does not work
Check and replace the door safety switch.
Posted on Feb 15, 2009
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
Cuisinart Microwave just suddenly shuts off all power
It may be overheating due to a clogged vent. moove the vents away from the walls and check they are not blocked. Never try to fix an appliance while it is plugged in.
Jan 20, 2014 | Cuisinart Microwave Ovens
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
The microwave control panel suddenly went blank. I checked the power at the outlet and it is fine. There wer eno fault codes or anything else - my guess is that the control panel failed
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. you can also take a bit from a screw driver or drill and place it in the fuse holder. then plug the microwave back in, and it should come on.
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The emerson microwave suddenly stops working,no power supply.
Two microwaves, 3 service companies and 6 service calls later, I think I have the answer. My unit is a MMV1153BAB but I'll bet the problem runs throughout the Maytag line. The units are ship from the factory set up to vent to the interior. If your want to vent outside, the fan in the right, rear, upper coner needs to be repositioned. Tell the service tech to go to servicematters,com and follow the link for technicians and find service pointer K8178715 issued in 2007. My unit has now run 20+ minutes with no problem and no moisture buildup.
Oct 15, 2009 | Maytag MMV1153A Microwave Oven
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Galanz Microwave problem
its more likely to be a fuse from the transformer to the cap or the diode.
Sep 14, 2009 | Microwave Ovens
Locks up and powers down during use leaves a F2 display on the clock window
Can't tell by pict for sure, IF this is a Microwave that is vented. Is it possible your vent it needs to be cleared. Sounds like possible moisture in the microwave, This would shut it down in the middle of a cycle. The moisture would happen from poor or clogged venting.
May 04, 2009 | Whirlpool MH1150XM Convection/Microwave...
Touch-pads unresponsive
Some newer models have a child lock feature which can be accessed via a HELP or CUSTOM HELP pad. On recent LG models, try pressing the "0" key for 5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Has anyone ever sprayed cleaner directly on the keypad? Has anyone ever boiled on the stovetop without running the hood vent fan? Is the hood vent clogged? Any of these can cause moisture buildup on the control circuit board or in the keypad, which can cause odd problems like this. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Please let me know if I can help further:
Sep 22, 2007 | LG LMVM1945 Microwave Oven
Whirlpool GH8155XJ Microwave Oven Logo
49 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
