Question about Garden
How to replace Pump Drive Belt on 23HP Scag Mower
4 Suggested Answers
  • 8404 Answers
SOURCE: Cahnging drive belt on mower
dont understand your question ... get the belt ... it was designed to fit ... there are probably at least three pulleys. put the belt around the motor pulley and the trans pulley then figure out how the clutch or tensioner pulley interact with it.
Posted on May 01, 2010
SOURCE: I am trying to find out how to replace the mower
Replacing the belt is easiest if you drop the deck. There are roughly 6 pins you must pull (refer to sticker on deck) including the engagement cable. Pull the deck from under the tractor and remove the plastic pulley shield from the left side. Remove the belt and replace the same as you took off and re-attach the deck to the mower.
Posted on Jul 22, 2010
SOURCE: After running husquavarna riding
I had the same issue and after trying everything I tokk the gas cap off and noticed there was negative pressure in the fuel tank when I broke the seal... I'm pretty sure the gas cap was just too tight, I threaded it back on but did not torque it down and the mower is running fine.
Posted on Jun 16, 2011
Diagram of drive belt for husqvarna rz4623
Hi Willard, The link below is a web page with the diagram for your lawn mower.......CHEERS..
Diagram of drive belt for husqvarna rz4623 Google Search
Apr 17, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Having trouble with noise from the drive system and failure of drive belt
Replace drive belt, check any pullies and bearings.
Nov 19, 2014 | Garden
My 36 inch scag mower skips whilein drive speeds
Could be the drive belt slipping or a gear slipping. I would try the belt first.
Oct 08, 2014 | Garden
Drive belt configurataion
There shoud be a belt scematic under the foot well plate.
Sep 23, 2013 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My husqvarna lawn mower makes clinking or rattling noise when I let off clutch
It sounds like there is a piece missing from the drive belt. The drive belt would be the upper belt on the drive pulley at the bottom of the engine. Another thing it could be is a bad bearing in an idler pulley.
Sep 23, 2012 | Husqvarna YTH2348 960430035 23HP 48 Yard...
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
