Question about Krups SensoToast Deluxe 4-Slice Toaster
Krups Sensotoast Deluxe -- Stopped working!!! Checked outlet. Not the problem.
Did the same to me
The ceramic heater to wire connection broke off
not a prayer of fixing it
The heating elements are in a series circuit, so as goes one element, so goes both elements.
Posted on Dec 21, 2010
Krups wont turn on
Check circuit breakers more than likely one is tripped .check a gfci- outlets . A lot of times kitchen outlets are tied in to ground fault recepticles. Commonly called gfci 's. If it has a light on it that is lit up press reset button. If it clicks and stays lit it's bad and needs replaced.
May 26, 2014 | Krups Coffee Makers & Espresso Machines
Krups coffee exresso/coffee maker
Check fuse/breaker for that outlet. Try another outlet....
May 11, 2013 | Krups XP2070 Programmable 10-Cup...
My Krups Sensotoast Deluxe just stopped working. Can you help me? I really don't want to throw it out because it's relatively new and I expected a product with this name to last a lot longer.
The printed circuit board is likely burned out. It's pretty sad really. This is a poorly designed toaster. Krups owes us new toasters in my opinion. Looks like a fire hazard too. If you are curious, you can remove the 4 philips head screws out of the bottom of the toaster, gently pry off the push down lever and the dial, and examine the board and connections. 8_25_2012_1_16_19_pm.jpg
Mar 27, 2011 | Krups 287 SensoToast Deluxe 4-Slice...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
It stopped as I was pushing leaves through it
there might be a red button (overload) on the motor.
Nov 07, 2009 | RTO Deluxe Electric Leaf Shredder
The toaster was turned upside down and now it will not heat. The carriage does stay down
Sfety switch needs reset. Open the bottom and look for a switch in the cord wires circuit.
Sep 07, 2009 | Krups 287 SensoToast Deluxe 4-Slice...
Krups toaster won't work.
I do not know the exact inner workings of this toaster, but I can suggest what the fault may be.
Many of the toasters use a separate high power section in the eating element for toasting. This part of the element could have gone defective. There is the possibility the computer board that directs the power for the higher temperature mode for toasting has failed.
The only reliable way to know is to try the computer board, element assembly, or the switches if the switches are on a separate module than the computer board.
Just to add... These toaster units usually have a thermo protection fuse. These fuses have a temperature rating. It would be in series with the element. This fuse may have failed. This is a common fault in many of these types of units. This type of fuse is rated in Degrees C or F, and not in Amps. it is a thermo fuse.
Apr 02, 2017 | Krups 287 SensoToast Deluxe 4-Slice...
Problem with jaipan toaster
the release mechanism contains a bimetallic strip that snaps open when a certain amount of power goes through it based on the setting. When cold, it should trap the toast loading lever mechanism. If not, it may be broken or bent. Don't work on it with power applied
Nov 21, 2007 | Krups 288 SensoToast Compact 2-Slice...
Krups SensoToast Deluxe 4-Slice Toaster Logo
223 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
