My Simpson esprit 450 is not draining or spinning properly, it's leaving a small amount of water in the bottom and doesn't seem to spin.
  • 3 more comments
  • m_robbins27 Jan 05, 2009
    my simson esprite 450 dos'nt spin and also leaves water in the bottom
  • BJ0475 Mar 04, 2009
    I have exactly the same issue, the machine doesnt spin properly and leaves the clothes wet.
    Ive checked the pump and it seems fine.
    The clutch and motor appear to be working properly.
    I tend to think it is electrical or maybe a timing issu.
  • Anonymous Apr 01, 2009
    Same for me, the rest of the wash cycle is fine but come time to spin, the bowl sits there with what sounds like the pump running.  There is a new sound associated with this, almost like a short 'whizz' finishing with a 'click'.
  • Anonymous Apr 12, 2009
    I have the same problem as the rest of you guys.
  • ostlerc Apr 18, 2009
    same problem. THe machine only actually washes periodically. Fills with water then runs through the cycle with no agitation.
5 Suggested Answers
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: my simpson esprite 450 dos'nt spin and leaves water in the bottom
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
dcramer531
  • 1654 Answers
SOURCE: Simpson Clothes Washer - Esprit
This machine has a hystory of motor control board issues and this sounds excactly like the symptons. The timer part of the controler seems to be skipping. The problem is the whole control board may need replaced.
Posted on Jan 03, 2011
KevinWhite
  • 1902 Answers
SOURCE: Hi, my simpson esprit 450
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on May 13, 2011
  • 713 Answers
SOURCE: simpson esprit 450 washing machine timer not
Hi just read your posting.Now just a couple of questions.What water temp have you set the machine for,Is it cold,cold or another setting.Have you got the cold hose going from the cold tap to the cold water valve on the machine with is marked with a C and the same for the hot which is marked H.Please reply with answers to all the questions and I am sure I can help you with this fault.Looking forward to your reply.
Posted on May 24, 2011
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do I get my washing machine to spin
Check the interlock tab (upright models) or the hinge or latch switch (front-load.) Sometimes these switches break or simply come loose.
Aug 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
My Simpson Esprit 655 washing machine is not the spinning the clothes dry. Everything seems to be ok.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Washing Machines
Simpson esprit 450 washing machine timer not working. It statrs at a certain point (rinse) but doen't work when I set it for wash. It does rinse, deep rinse and spin but doesn't wash at all.
May 24, 2011 | Washing Machines
Not spinning or draining
Remove the lower rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve your problem.
Please leave feedback.
Thankyou.
Jan 04, 2010 | Hotpoint Washing Machines
Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Dec 27, 2009 | Washing Machines
Simpson esprit 450 washing machine top loader
Apr 11, 2009 | Washing Machines
My simpson esprite 450 dos'nt spin and leaves water in the bottom
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jan 05, 2009 | Washing Machines
My simpson esprit 600 is not agitating during wash cycle it only goes one way
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Aug 18, 2008 | Washing Machines
Washing Machines Logo
1,478 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
