Question about Polar Watches
A small irregular shadow appeared on my watch screen. It does not depend on the operating mode. eventhough it is small, it is annoying. What can I do to fix that? does it help to reset my polar watch s625x? Thanks for any suggestion
  • 2,334 Answers
Pop into nearest watch repair shop, because this is sign of water getting in. Another one could be if you knocked it. Anyway- look for pro attention.
Posted on Aug 06, 2010
Testimonial: "Thanks I will do that"
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Feb 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Setting Date & time
mcdevito75 here, generally you need operate 2 bittons to set your Casio watch, the MODE and SET buttons. Press the Mode button, you may have to hold it in for 2-3 seconds, see the display falshing, press MODe to go to each function, once at the function you want to adjust, press SET press MODE to move onto next function, once all functions are set, press MODE for steady display. If this fails, look for a small watch repair shop in your area for help setting up the watch.
Feb 11, 2011 | Casio Watches
We bought a sportline solar watch that has a light mode and rerset and st/stp function mode we want to set the time but don't know how? Help please
mcdevito75 here, I see in your question, SOLAR if that means the watch is operated from the sun"s energy, you first have to get the watch going (ticking) before you can set the time, Instead of a Battery your watch has a capacitor that holds onto the sun"s energy and releases it, makeing the watch go (tick). After the watch goes, you need worry about 2 buttons, MODE & SET. Press MODE and see display Flashing, now press set to set each function, (hour, minute etc.) presss MODE after ecah function is set to move on, once all functions are set, press MODE for steady display, also if thew watch is new, look for a small piece of plastic just under the crown, remove that plastic and push crown down to start watch. Hope this helps.
Jul 04, 2010 | Watches
Rubber with screen in the middle, well rubber is tearing in half. i would like just to replace the band!
mcdevito75 here, You may have to return the watch to the manufacturer, depending of course on the maker of the watch, Best Bet, visit a small watch repair shop in your area, see what they say.
Jun 27, 2010 | Watches
Operating buttons on wenger watch
Go to the Wenger web site (wenger.com).
Select "watches"
At the bottom of the page there are a number of tabs, select "services".
On the right hand side of the screen are two options below the search box, select "booklets"
Opposite "instruction's booklet" there is a small red tab, select this and the instruction booklet for all Wenger watches will appear.
Jan 05, 2010 | Watches
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Time
Hold in the MODE button until the alarm time appears.
VERY IMPORTANT - Tap the MODE button again, and the time should appear with the seconds flashing.
Use StART/Stop to choose among seconds, hours, and minutes, and
Use ADJUST to increase the selected number
Press MODE to put the thing back in regular operational mode
May 06, 2008 | Timex 1440 Nylon watch
Watch problem
take out the battery and clean under it and the area it is supposed to be settled in.Clean with rubbing alcohol.
May 13, 2007 | Casio E-DataBank DBC3101 Wrist Watch
Problem with watch
it could be a bad battery which would have functioned for a while then went bad. if you take it to a watch store they can try a new battery if it works buy it if it doesn't then don't. even some walmarts in the jewelry dept have the batterys
Nov 08, 2017 | Casio E-DataBank DBC3101 Wrist Watch
Casio Databank watch
The replacement battery may be defective.
Watches Logo
193 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
