Question about Akai LCT2660 26 in. HD-Ready LCD Television
No power i have the same problem can you help me out . i just a beginer in electronics , can you show mw how to chech it and repair it please .
    Champion:
  • 367 Answers
Once you open the back of the TV,look at the can shaped items on the board that the power cord plugs into.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on Apr 27, 2008
Look like is gona work but,i click start is not work
please see the next topic:
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
Sep 07, 2012 | Microwave Ovens
Trouble shooting
see the next step and proceed with common sense: God bless you
Jul 26, 2012 | Sanyo Microwave Ovens
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
Hi sir Gud morning i have an lg gd510 pop mobile phone but it is not playing online videos like Youtube simlpy showing chech APN settings pls help me
hi sir Gud morning i have an lg gd510 pop mobile phone but it is not playing online videos like Youtube simlpy showing chech APN settings pls help me
Jul 01, 2011 | LG GD510 Cell Phone
The microwave stopped microwaving, but the clock starts to countdown
Hi, with the MW ovens, there isn't too much to go wrong, and when they do there are three places we check, One the main circuit board, two the Magnetron and three the Power Supply in particular the High Power Diode.
MW's are VERY DANGEROUS to service, as they have a VERY large Capacitor in them which if touched when charged WILL KILL YOU,therefore I usually try and dissuade anyone from DIIYing a MW. Only skilled engineers should undertake repairs i feel.
In any event I would think that your problem is indeed the magnetron/High Power Diode., it usually is.
Please take the Unit to a reputable repair center, now when there ask for a "Quote" before allowing repairs to start. This way you will get an idea of costings, as you see often the replacement costs, like a magnetron can easy cost the repairer $100.00, and the cost of repairs can quickly approach the cost of a New unit, with a warranty... thus when armed with the costings one can then make an informed decision as to what to do,.
Aug 19, 2010 | GE Microwave Ovens
Monitor won't power up
Please recheck your cable connections & power button/switch, also try to review the product / operations manual (if you have a copy) which might have troubleshooting guide/s htat is related to your problem. best regards
May 15, 2009 | LG Flatron MW-30LZ10 30" LCD Monitor
HI I have the tascam 2488 mk11....have only had it a little over a year....has about 20 hrs. playing time on it as I haven't had time to use it.....Today it gave me the following message; CANNOT BOOT...
This is often due to the HD not getting enough power to spin up to proper speed when booting. Usual suspect is the power adapter. You might try picking up an after market one that matches the specs before going through the expense and trouble of shipping the unit back.
Feb 19, 2009 | Tascam 2488 Portastudio Multitrack...
OUT OF RANGE
Sounds like the Video setting is too high. Change the refresh rate lower and change the resolution lower. You monitor can't handle the setting that you have it on.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Jun 04, 2008 | Toshiba Satellite LP154W01 Notebook
Akai LCT2660 26 in. HD-Ready LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
