Question about Sony PlayStation 2 (PS2) Console
Need information on Master Mechanic 16" single speed scroll saw model mm8354sl model for maintenance (oil,etc..) and changing blade. I have no manual for the scroll saw. Need help ! Thanks Lance
I can't see how to change blade. Do I need to take off the table part? I can't get to the bottom attachment part I have the 16'' Ryobi portable scroll saw
Theblade has a small rod on each end that locks the bladeon.. Pull the blade outward and pressthe top arm downward to remove the blade
Jun 02, 2010 | Craftsman 16" Variable Speed Scroll Saw
How to change the blade on a craftsman scroll saw? The manual was been misplaced when we moved
You might be able to find the manual on the Sears site (this can be a frustrating search - but start with the model number). But even without the manual, this is pretty easy on most scroll saws. There is usually a plastic knob (about the size of a ketchup bottle lid) on top of the machine at the back. You loosen this knob a couple of turns (to the left) and the blade will become very loose. The blade is probably the "pin-end" type - it will have a little cylinder about a 1/4 inch long on each end of the blade. You can buy new blades at any home improvement or hardware store. Besides qualtiy, the main differences will be the length of the blade and the size of the teeth (expressed as TPI or Teeth Per Inch). You need more TPI for cutting harder and thinnner materials, less TPI for softer and thicker material. Put the new blade in like the old one was (teeth pointing down) and tighten the plastic knob. It's hard to be sure how tight is should be, since it doesn't suddenly tighten up. About a 1/4 turn past where is starts to get noticeably tighter is a reasonable place to start. If the blade pops off during use, it wasn't tight enough.
Jan 14, 2010 | Craftsman 16" Variable Speed Scroll Saw
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Sony PlayStation 2 (PS2) Console Logo
313 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
