Question about Microwave Ovens
Model JMV8000 Jenn-Air Microwave
Microwaves exhaust, interior light, and turn table all shut down at the same time. What can I do to fix it, or would I be better off buying a new microwave.
  • Microwave Ovens Master
  • 9,098 Answers
I would say one of the thermal fuses has blown, either the one for the magnetron or the cooking cavity. This is a simple and inexpensive fix for a DIYer.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find the full service manual for a similar model here.
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will have exact troubleshooting details.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
I have the Jenn-Air microwave oven. It is mounted in a cabinet. How do I replace the light? Should I try to remove the microwave from the cabinet? If so, how is this done. The manual is vague on this. It...
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Sep 10, 2010 | Jenn-Air Microwave Ovens
Microwave does not seem to heat enough
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jgk
Aug 09, 2010 | Jenn-Air JMV8000 Microwave Oven
Everything works, sounds normal, but it will not heat anything.
Owners of a GE WES model might want to look at this blog post.
Hopefully its still under warranty.
If so, GE Customer Service is here.
If not, I'd replace the oven.
Jan 08, 2010 | Jenn-Air JMV8000 Microwave Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
Sharp Carousel R-930CS-F Wont heat
CHECK YOUR FUSES. IF GOOD IT MAY BE THE MAGNETRON IS BAD
Apr 17, 2009 | Jenn-Air JMV8000 Microwave Oven
Microwave went POP and stopped.
probably not the fuse. If it is, then something caused it to blow as a fuse is a safety device. Since microwaves can be dangerous due to the radio waves, here is what I've done in the past. I had Sears come out and diagnose the problem. Before tech left, I told him I don't have the money to fix it now but will do it in a month or two. I had him write down the parts I needed and the part numbers so when I do want it fixed, I do not have to start at ground zero. He was glad to help. I watched everything he did, and since I work on commercial microwaves, amana, it was no problem for me to order the parts and do the repairs myself. My microwave is a 1200 watt over my stove.
Keep in mind that microwaves are getting so cheap, that you may want to look into just what a replacement will cost.
Feb 05, 2009 | Jenn-Air JMC8100 Microwave Oven
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
